- Nov 25, 2013
Import over the UI always uses /mnt/somepool. To get the same when importing on the command line you need to specify
I'd really love to see someone who knows this GELI encryption better than I do jump in and help you get your pool to a sane state, because all the steps that happenend so far, while inconvenient, are perfectly deterministic and solid. And I do trust in FreeNAS that it is possible to restore a sane configuration without starting over.
Tldr; How does one attach a new device to a single disk vdev to form a mirror if the pool is geli encrypted?
Any takers?
-o altroot=/mnt if I remember correctly. I am currently away from my system, so can't check.I'd really love to see someone who knows this GELI encryption better than I do jump in and help you get your pool to a sane state, because all the steps that happenend so far, while inconvenient, are perfectly deterministic and solid. And I do trust in FreeNAS that it is possible to restore a sane configuration without starting over.
Any takers?
