looperkooper
- May 31, 2021
Hello everybody,
And installed TrueNan on a computer and everything worked out fine.
But at the moment of creating a Pool and adding the disc it tells me "A stripe data vdev is highly discouraged and will result in data loss if it fails" but select force and I proceed to create the Pool with the selected disc. At that moment I get the error "'utf-8' codec can't decode byte 0xc3 in position 19: invalid continuation byte"
and I can't do anything else anymore, I can't find the solution anywhere.
