Using Official Apps with Ingress + Reverse Proxy to other services
victort
Is there any way within SCALE to use the official apps with Traefik or some other built in ingress controller to allow the use of only a domain, instead of a domain with a port number to access?
The reason I ask is tha I would like to use official apps (Nextcloud, Vaultwarden) as opposed to Truecharts apps because of some issues I'm having. Specifically that Truecharts Vaultwarden app will not deploy at all while using hostpath for storage, but the official app works fine.
Also with the official Nextcloud app it is possible to delete the app, and reinstall it while simply pointing the hostpath storage back at your existing data. With Truecharts this is not exactly possible without having to do some manual work to migrate or mount the data.
You should be able to do this using the (TrueCharts) external service app, much like they document for accessing the GUI itself:
Chubblez
To make sure I understand what you're asking:
https://server.domain.tld should display the TrueNAS scale UI
https://nextcloud.domain.tld should show NextCloud
https://vaultwarden.domain.tld should show Vaultwarden
All via one IP address, and only using official apps. Is that correct?
victort
Chubblez
Correct.
And using the external-services app is the way to do it.
I'm trying to get the same thing setup, though I may be adding complications.
Vault Warden - vlan 1 - custom SSL certificate
Next Cloud - vlan 1 - will require Active Directory access - custom SSL certificate
Plex / Emby - vlan 1 - will stay on their preferred service ports
Home Assistant - vlan 2
In my case, I'm fine assigning separate IP's to the service to match a DNS entry, but Vault Warden and Next Cloud have to present to the apps over 443.
If you're not using any TrueCharts apps and only official ones, I would suggest using the community app "nginX Proxy Manager" for ingress control.
victort
You can still use Traefik if you want. My setup is similar to this video
I have one IP serving my TrueNAS GUI and one IP for the Apps. With Traefik or nginx, it doesn't matter which port you set the services to run on. That's the idea behind a reverse proxy. You just need to configure your DNS entries to point to the proxy, and the proxy then takes the domain and redirects it to the proper IP/port.
The difference is that to use official apps (and other services) you need to use another Truecharts app called “external-services”
This allows you to configure everything with Traefik. Just fill in your domain, port, and cert to use just like you would in the other Truecharts apps.
Darren David
I like this idea of using a separate IP for the Apps. Are you configuring a second IP on a second NIC, or are you doing this virtually?
Also, should it matter if I'm running nginx on another machine, or does it need to be running on the same machine as TrueNAS Scale for ingress to work properly?
victort
I don’t do this anymore, but when I did, I assigned both IPs to one bridge. The bridge had the main NIC as a member.
sfatula
Yes
