Hi all,
is there any way to use an external USB with Freenas?
I've plugged it in, but I don't see it under the storage menu. Am I supposed to run any command at all?
I'm running the latest version 8.0.3
Not for sharing, just for migrating files from it to your NAS. If it works for you, you should see it when you "Import" it From Storage -> Volumes -> Import Volume
Take the warnings in the link below seriously. NTFS on FreeBSD is not stable/reliable.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
