well we are in the process of moving from openfiler, fortunately we hadn't deleted anything really from the source drive so it was a matter of just getting stuff pointed properly again.
OK things on this are still not going well... I would like to put a different Raid controller in my 2950 or an HBA that fits in the same place as the current H700 hopefully using the same cables.... if I can't do that what card natively supports JBOD that can be used in a 2950 and what cables will I need if it won't fit where the existing card is or can't use the existing cables I have?
You should be ok with a M1015 crossflashed to P16 IT firmware, or a LSI 9211-8i with IT firmware. You should be able to use the existing cables, a quick google of the H700 shows it has SAS cable connections so thats good.
Do you have a picture of the inside of the case? The H700 has the cables on the top(?) of the card i wanna say, rather then the back. If so then the cables should fit the M1015 fine as the M1015 has top SAS connections as well
