Uptime chart not persisting through reboots
SubnetMask
I've noticed something that may be a bug, or maybe not - When I go to 'reporting' > 'system', and look at the 'uptime' chart, as of now, every line shows 69 days, 5 hours 57 minutes, except for the 'average' line which shows 69 days, 5 hours 29 minutes, and the 'Total Run', which shows 57 minutes. All of these values reset on every reboot. I would expect the 'Current' line to reset every reboot, but I would also expect the other lines to not reset - so maximum should read the longest the system has been up, and only change when the system exceeds that longest runtime, minimum should show the shortest duration the system was up and should only change if the system is up for a shorter time, average, obviously, should be an average of these, and I'd expect 'Total Run' to show the cumulative runtime of every minute the system has been up.
Any thoughts on why these counters all keep resetting?
Chris Moore
It has never persisted through reboots. This is a 'chart' that has never really made sense because it starts over after every reboot and just continues to increase until the next reboot when it resets again. The way you describe the function would make some sense. I agree, perhaps it is a bug, but if you want to change the behavior, that would need either a feature request or a bug report.
To start that process, go to: https://redmine.ixsystems.com/projects/freenas
where you will need to create an account and then you can submit a bud report through the WebGUI in your FreeNAS system:
https://www.ixsystems.com/documentation/freenas/11.2/system.html#support
