UPS on another machine using apcupsd
Joe Kool
Hi!
I am running apcupsd on another machine and tried to set up NUT on FreeNas-9.10.2-U5 (561f0d7a1).
It does not work.
I'll appreciate any hints how to get this running.
But in the meantime, I wanted to deactivate NUT, as it produces errors every 5 seconds:
Jun 19 21:56:21 freenas upsmon[37783]: Poll UPS [APC550@192.168.192.20:3551] failed - Driver not connected
Jun 19 21:56:26 freenas upsmon[37783]: Set username on [APC550@192.168.192.20:3551] failed: Write error: Broken pipe
What can I do to stop nut/upsmon an all applicable services.
From the web-interface, I did not find a possibility.
Thanks
Joe
BigDave
FreeNAS Enthusiast
Go into the Services and turn off UPS
Spearfoot
He of the long foot
Hi!
It does not work.
Thanks
Joe
See my "Configuring UPS support for single or multiple FreeNAS servers" post in Resources.
Make sure you've configured the same TCP/IP port, user name, and password on both the local and remote systems.
Good luck!
