rmccullough
- May 17, 2018
I have my UPS connected to my pfSense router. It seems to be configured properly and the status is able to be monitored there.
However, I am getting these errors in my /var/log/messages:
However, I can pull the status from my TrueNAS server:
Any idea why I am getting these disconnect errors?
May 19 08:27:40 freenas 1 2022-05-19T08:27:40.833515-06:00 freenas.local collectd 80463 - - nut plugin: nut_read: upscli_list_start (ups) failed: Server disconnected May 19 08:27:43 freenas 1 2022-05-19T08:27:43.861438-06:00 freenas.local upsmon 80369 - - Poll UPS [ups@router:3493] failed - Server disconnected May 19 08:27:43 freenas 1 2022-05-19T08:27:43.861467-06:00 freenas.local upsmon 80369 - - Communications with UPS ups@router:3493 lost May 19 08:27:48 freenas 1 2022-05-19T08:27:48.874558-06:00 freenas.local upsmon 80369 - - Login on UPS [ups@router:3493] failed - got [ERR ACCESS-DENIED] May 19 08:27:53 freenas 1 2022-05-19T08:27:53.909989-06:00 freenas.local upsmon 80369 - - Communications with UPS ups@router:3493 established
root@freenas[/usr/local/etc/nut]# upsc ups@router battery.charge: 100 battery.charge.low: 10 battery.charge.warning: 20 battery.mfr.date: CPS battery.runtime: 1417 battery.runtime.low: 300 battery.type: PbAcid battery.voltage: 27.0 battery.voltage.nominal: 24 device.mfr: CPS device.model: CP1500AVRLCDa device.serial: CXEJP2006797 device.type: ups driver.name: usbhid-ups driver.parameter.pollfreq: 30 driver.parameter.pollinterval: 2 driver.parameter.port: auto driver.parameter.synchronous: no driver.version: 2.7.4 driver.version.data: CyberPower HID 0.4 driver.version.internal: 0.41 input.voltage: 120.0 input.voltage.nominal: 120 output.voltage: 136.0 ups.beeper.status: enabled ups.delay.shutdown: 20 ups.delay.start: 30 ups.load: 27 ups.mfr: CPS ups.model: CP1500AVRLCDa ups.productid: 0501 ups.realpower.nominal: 900 ups.serial: CXEJP2006797 ups.status: OL ups.test.result: No test initiated ups.timer.shutdown: -60 ups.timer.start: -60 ups.vendorid: 0764
