Upload limited at 100mbit/S
Tecmac
Question:
What could be the reason that I have 238.7mb/s in download but only 98.15mb in upload? The server is plugged direct to the router via a cat 7 cable.
Hardware Spec:
motherboard: https://www.gigabyte.com/Motherboard/GA-AB350M-DS3H-V2-rev-11/sp#sp
APU: Amd ryzen 3 2200g
Pool: 2x HDD Raid 1
Ram: 12GiB ddr3
Constantin
Vampire Pig
Use case likely matters. Ie. Are you reading and writing the same types/sizes of files? For example, most NAS’ performance is reduced by smaller files.
I’d expect slower writes than reads - the former requires checksums, parity writes, etc overhead while the latter is a straight read from the source.
Tecmac
I tested it by streaming from jellyfin.
Do you think that the Realtek chipset on the motherboard is the bottleneck?
Constantin
Vampire Pig
I don’t have experience with your Realtek chipset, but folk in general are unhappy with Realtek and recommend alternatives. That said, I doubt the chipset is at fault here, I suspect it’s read vs. write but I’d prefer if someone with experience in Jellyfin could pipe up and confirm that for you. Sorry!
