upgrading to 9.3 .iso file
Mucip
I downloaded 9.3 stable ISO and write it on CD. I bought two 16 GB flash discs. I start to fresh install on 16GB disc by USB external DVD driver. Unfortunately I got SCSI error. Same machine and same setup?! What is the problem with the new 9.3-stable? 9.2.1.7 working on this machine without any problem. But 9.3 has error.
By the way I re-wright ISO on new DVD but nothing happened. Same error...
Error screen attached...
SweetAndLow
Sweet'NASty
can you write the iso to a usb stick and try that? might be the cd drive having issues over usb.
Mucip
Ok. I will try this tomorrow morning. Can I use same ISO to write on USB like by below command:
dd if=FreenNAS.iso of=/dev/sdb bs=4M; sync
Or should I use other ISO file?...
Regards,
Mucip:)
Mucip
Dear All,
Finally I got it easily. Thanks for your kind help.
I wrote ISO to usb using above command and install 16GB flash without any problem. Then I uploaded the config from 9.2.1.7 to 9.3-Stable. Perfect.
And I finally upgrade the ZFS volume. Now everything work like a charm... :)
Thanks again...
Regards,
Mucip:)
