Hello!
I currently run a small NAS at home with 2x4TB disks in RAIDz1, but I am running out of space. I am also thinking of using a (really old) PC for offsite backups.
My NAS is used for storing my music collections, as well as recordings of my livestreams. So there is no need for any extreme performance.
My current spec are as follows:
A2SDi-2C-HLN4F with Intel Atom Processor C3338 and 2xSamsung 8GB DDR4 ECC
2x4TB Seagate Ironwolf
Fractal Design Node 304
Corsair CX550M 550W
24gb SSD as cache drive
16Gb SATAdom systemdisc
To achive this I have some questions:
First:
I (think I) want my home storage NAS to have at least two discs reduncancy, the thought of one disc failing and then another failing before I get another disc makes me cringe. So I have this idea:
My case have 6 3.5" slots, and my motherboard supports 8 SATA connections (1 for systemdisk. 1 for cache and 6 available for storage)
Is this a reasonable approach or should I just get 2 bigger drives and mirror them instead?
The following are the ideas I've had so far:
Secondly:
Should I try to get the same drives as the ones I already have, or should I try to "spread" the MTBF by using different brands/model#? I will offcourse double check that any drive I chose CMR.
Thirdly:
I have a superold Dell optiplex 745 that I thought I'd use for offsite storage. As it is super old I installed Truenas to make sure it worked at all, which it did. As it will only be used to backup storeage I don't think the abysmal performance it may have will affect anything?
Thanks in advance for any help for my inquires!
/Jaxcie
Corsair CX550M 550W
First:
- Get 4 more 4TB drives
 - Create a RAIDz2 pool with the new drives
 - Move data over from old pool
 - Add HDDs from old pool to new pool
| # of drives | Name | Size of each disk (TB) | Usable ZFS size | Price |
| 4 (+2 reused) | Seagate IronWolf ST4000VN006 | 4 | 14TiB | 4400 SEK |
| 2 | Seagate Exos X16 ST16000NM001G | 16 | 14TiB | 6000 SEK |
Secondly:
Thirdly:
/Jaxcie
