Upgraded to SCALE-22.12.1 and now my ZFS arc settings are not working.
Xero7650
Anyone else run into an issue where they were manually setting there ARC ZFS min and max size via CLI, and it is no longer working post upgrade? I noticed it post reboot even though I set it up under System Settings --> Advanced --> Init / shutdown scripts to run the commands on boot. I manually reran the commands from the CLI and they executed without error, but the amount of memory being used is not changing.
Anyone else run into a similar issue?
Xero7650
if you re-run the commands manually, it will eventually work. However saying that, Ive seen free ram creep back up to half un-utilized leaving me with 256GB of RAM free (no reboot).
I then re-run the commands from the shell, and it starts working again.
donnyb99
Oddly enough attempting to run this from a user or admin account with sudo did not work, nor did attempting to run from a root user chron job. However, when I manually went in to shell as root, it worked no problem. I was getting permission denied with all the other methods. Anyone know the reason for this behavior?
Samuel Tai
You're setting them in the wrong spot, if you're trying to use a cron job or a post-init script. The correct location to set sysctls that will persist is under System Settings->Advanced->Sysctls
donnyb99
Cron jobs and post-init scripts always worked for me prior to 22.12.1. Can you shed some light on what to input in the variable field for sysctls to set the max arc size?
Xero7650
so did things change, I had been using a post init script previously and it was working great. I am open to changing how I do things; but can you explain a bit more?
do I just use the variable name and set the value? Meaning the following:
Setting Name: zfs_arc_min Value: 274877906944
or do the value keypair names change when you move to sysctls?
Thanks for the info!
Xero7650
I did some digging and i'm not seeing any tuneable for arc via sysctl - so definitely could use a pointer.
Samuel Tai
Try running arc_summary. It should provide a comprehensive list of all sysctl tunables.
donnyb99
The tunables listed in arc_summary do not work as listed in sysctl on Scale. When trying to enter zfs_arc_max as a variable, Scale reports, "
Sysctl 'zfs_arc_max' does not exist in kernel."
Perhaps that only works on Core and not on Scale? As far as I can tell, there are no sysctl tunables for zfs on Scale. If there are, please give me an example that works so I can try it out.
ls /sys/module/zfs/parameters/
StevenD
Are you doing a Init/Shutdown Command similar to below?
echo 274877906944 >> /sys/module/zfs/parameters/zfs_arc_min
For sysctl, I think it would be vfs.zfs.arc.min. Though that might be the value for Core and not Scale. I do not know if they are different. In Angelfish, the above was the work around because as far as I know sysctl did not work.
I attached an image as for reference. The image is a different variable / value but encapsulates all the other settings that are working for me on Bluefin. Hopefully, the tunables are all added properly in the future and we can use sysctl directly as we are supposed too, but for now this works.
neofusion
Core and SCALE probably work different here.
Unless something has changed ticket NAS-116472 still applies and you can't do this in the UI for tunables on SCALE.
donnyb99
I think this is the correct answer to sysctl on Scale.
This worked flawlessly before 22.12.1 however now it doesn't seem to work. It returns a permission denied error. Only by running as root through the shell was I able to set this correctly. Even a cron job or init script set to run as root doesn't seem to work.
StevenD
Interesting, I upgraded my server yesterday to 22.12.1 and the script is still working here, no permission issues.
TShiny
Same issue here. Newly installed 22.12.1, the script(sudo) was permission denied, and `Sysctls` shows `Sysctl 'zfs_arc_max' does not exist in kernel.`
li_chang
You can do some workaround like this:
sudo sh -c 'echo NEW_ARC_SIZE > /sys/module/zfs/parameters/zfs_arc_max'
