Hey guys,
I searched and couldn't find anything on the symptoms i have with my FreeNas installation. I was running 9.1 release, and it was working fine. no errors, in the log, plugin working, file sharing working fine.
well.. then i upgraded via GUI to 9.2 beta. after that i get errors in the log files...
Dec 7 20:53:33 freenas smbd[34355]: Unable to open new log file '/var/log/samba/log.smbd': No such file or directory
Dec 7 20:53:37 freenas smbd[60114]: [2013/12/07 20:53:37.868553, 0] ../lib/util/debug.c:571(reopen_logs_internal)
Dec 7 20:53:37 freenas smbd[60114]: Unable to open new log file '/var/log/samba/log.smbd': No such file or directory
Dec 7 20:56:33 freenas smbd[34355]: [2013/12/07 20:56:33.929562, 0] ../lib/util/debug.c:571(reopen_logs_internal)
Dec 7 20:56:33 freenas smbd[34355]: Unable to open new log file '/var/log/samba/log.smbd': No such file or directory
Dec 7 20:56:38 freenas smbd[60114]: [2013/12/07 20:56:38.036558, 0] ../lib/util/debug.c:571(reopen_logs_internal)
Dec 7 20:56:38 freenas smbd[60114]: Unable to open new log file '/var/log/samba/log.smbd': No such file or directory
Dec 7 20:59:33 freenas smbd[34355]: [2013/12/07 20:59:33.932550, 0] ../lib/util/debug.c:571(reopen_logs_internal)
Dec 7 20:59:33 freenas smbd[34355]: Unable to open new log file '/var/log/samba/log.smbd': No such file or directory
Dec 7 20:59:38 freenas smbd[60114]: [2013/12/07 20:59:38.146545, 0] ../lib/util/debug.c:571(reopen_logs_internal)
Dec 7 20:59:38 freenas smbd[60114]: Unable to open new log file '/var/log/samba/log.smbd': No such file or directory
Dec 7 21:02:33 freenas smbd[34355]: [2013/12/07 21:02:33.935554, 0] ../lib/util/debug.c:571(reopen_logs_internal)
I tried installing the 9.1 release again, with no help and then i noticed PLEX plugin wasn't working. I tried removing/re-adding, deleting and adding storage and the re-adding, nothing seems to work. In its current state, i can add the plugin, but when i try to turn it on i get a "Some Error has occurred" at the top of the web GUI window... duh! :)
CIFS, the web GUI work just fine. Plugins and the scrolling error message above are my issues. I tried adding sabnzbd plugin and it was giving me the same problem as the plex plug-in..
any help would be appreciated.
thanks!
thanks!
