wittend
- Oct 10, 2022
My System Partition (and all of my stored data) is Offline and I do not know how to restore it.
I see many reports of problems like mine, but usually there is hardware RAID, Proxmox, or other factors that don't apply to me.
I am not especially experienced with TrueNAS, but it has been working well for me for many months. I tried to follow recommendations (as well as I could understand them) when I set this system up, and tried not to make things complicated, Now after upgrading to TrueNAS-13.0-U6.1, things have fallen apart for me. I believe that I upgraded from TrueNAS-13.0-U2
My setup is:
16 GB RAM.
An older I7 motherboard with 4 SATA connections + a two port PCIe SATA card.
Two small SATA SSD drives for TrueNAS itself (attached to the PCIe card).
4 WD Red 4TB SATA drives attached to the motherboard SATA connectors.
No RAID, software or hardware.
Straightforward BIOS setup - no frills, twiddles or tweaks.
All drives visible at the BIOS level, no error reports concerning hardware.
1GB Ethernet, on the motherboard, not added in.
All NAS data is in one ZFS pool called unimaginatively) BigPool.
I backed up the system information to another machine before I applied the update.
The system continued to work well for a while, now it doesn't.
The Dashboard shows everything as normal except:
BigPool
Total Disks :
Unknown
Pool Status:
OFFLINE
Used Space:
Unknown
Under Storage / Pools:
BigPool (System Dataset Pool) OFFLINE [and a button] Export/Disconnect
No other pools to export to, no clue where to go from here.
Help!
My setup is:
16 GB RAM.
BigPool
Total Disks :
Unknown
Pool Status:
OFFLINE
Used Space:
Unknown
Help!
