SweetAndLow
Sweet'NASty
 - Nov 6, 2013
I was running on 9.2.1.7 and decided to upgrade to 9.2.1.8 since it has been out for a bit and I figured that if there are any issues they would have been found by now. After the upgrade my syslog doesn't seem to be working correctly and I noticed that the syslog and rrd datasets were renamed after the upgrade. In the link you can see the zpool history as well as the zfs list.
http://pastebin.com/HDaygHDB
I reproduced the issue in a test vm and got syslog working correctly by toggling the syslog and rrd setting under the system dataset tab. I'm not sure if this the correct solution and would like more input. I feel like they should have never been renamed in the first place.
