labtopia
- May 31, 2011
i've upgraded and since the upgrade connecting with afp is slow and finder then hangs, cifs is working fine.
i got the cnid error and told it from shell to rebuild the cnid db, that error went away but when i try to connect i get this kind of thing wherever the mac is hung up trying to browse the share- in the console:
i was set to use unix permissiinos and tried changing to ACL from the gui.
any thoughts on how to get afp working for me again?
: INTERNAL ERROR: Signal 11 in pid 14879 (3.1.1) Apr 2 16:29:00 labpod1 afpd[14879]: =============================================================== Apr 2 16:29:01 labpod1 kernel: pid 14879 (afpd), uid 1001: exited on signal 6 Apr 2 16:29:01 labpod1 afpd[20435]: Login by poduser (AFP3.4) Apr 2 16:29:01 labpod1 afpd[20435]: afp_disconnect: trying primary reconnect Apr 2 16:29:01 labpod1 afpd[55498]: Reconnect: no child[14879] Apr 2 16:29:06 labpod1 afpd[20435]: afp_disconnect: primary reconnect failed Apr 2 16:29:06 labpod1 afpd[20435]: parse_entries: bogus eid: 9, off: 50, len: 3760 Apr 2 16:29:06 labpod1 afpd[20435]: parse_entries: bogus eid: 2, off: 3810, len: 286 Apr 2 16:29:06 labpod1 afpd[20435]: ad_header_read(/mnt/pod1/LAB_BAK/installers/mac/._aclfix.dmg): malformed AppleDouble Apr 2 16:29:06 labpod1 afpd[20435]: Convert OS X to Netatalk AppleDouble: /mnt/pod1/LAB_BAK/installers/mac/._aclfix.dmg Apr 2 16:29:06 labpod1 afpd[20435]: =============================================================== Apr 2 16:29:06 labpod1 afpd[20435]: INTERNAL ERROR: Signal 11 in pid 20435 (3.1.1) Apr 2 16:29:06 labpod1 afpd[20435]: ===============================================================
