- May 28, 2011
Nope, that "zfs list" doesn't look correct to me. It shows you have 5.17TB of used storage however you look at the list of sub-directories and it doesn't add up, like you are missing a huge folder somewhere. If you have access to any data on this system, I'd back it up, although just over 5TB of data is a lot to backup. Yes, see what you get when you boot from FreeNAS 9.3, hopefully it will show where that 5TB of data reside. If you get the same results, I think you will be destroying your pool however someone might chime in with a solution but I'm a bit skeptical.
