While attempting to upgrade from 9.1.1-RC2 to 9.1.1-Release via the GUI upgrade method I am running into an issue. It basically wont upgrade and the logs are showing the following. It looks like (to me) that there is a disk inconsistency error on the USB boot drive /dev/da0s2a? Can I run chkdsk via remote command line to help address the issue? Server is remote and I would have to travel to run anything local. Any further insight on the problem and ways to resolve it would be great. Server seems to be running fine and boots up normally etc...
Thanks
Chris
Nov 22 08:19:35 archive root: + return 0
Nov 22 08:19:35 archive root: + BLACKLIST_EXPR=''
Nov 22 08:19:35 archive root: + INSTALL_DESTDIR=/
Nov 22 08:19:35 archive root: + INSTALL_SRCDIR=/mnt/Archive_1/.freenas
Nov 22 08:19:35 archive root: + VERBOSE=1
Nov 22 08:19:35 archive root: + getopts D:f:m:v opt
Nov 22 08:19:35 archive root: + shift 0
Nov 22 08:19:35 archive root: + realpath /
Nov 22 08:19:35 archive root: + realpath /mnt/Archive_1/.freenas
Nov 22 08:19:35 archive root: + stage=pre-install
Nov 22 08:19:35 archive root: + cd /mnt/Archive_1/.freenas
Nov 22 08:19:35 archive root: + [ -z pre-install -o ! -d pre-install -o 1 -ne 1 ]
Nov 22 08:19:35 archive root: + source_conf /mnt/Archive_1/.freenas/etc/avatar.conf NEW
Nov 22 08:19:35 archive root: + local IFS conffile prefix tmp
Nov 22 08:19:35 archive root: + conffile=/mnt/Archive_1/.freenas/etc/avatar.conf
Nov 22 08:19:35 archive root: + prefix=NEW
Nov 22 08:19:35 archive root: + [ ! -f /mnt/Archive_1/.freenas/etc/avatar.conf -o -z NEW ]
Nov 22 08:19:35 archive root: + mktemp conf.XXXXXX
Nov 22 08:19:35 archive root: + tmpconf=conf.zk1lgk
Nov 22 08:19:35 archive root: + sed -E -e 's/#.*//g' -e '/^[[:space:]]*$/d' -e '/^export /d' -e s/^/NEW_/g /mnt/Archive_1/.freenas/etc/avatar.conf
Nov 22 08:19:35 archive root: + . conf.zk1lgk
Nov 22 08:19:35 archive root: + NEW_AVATAR_PROJECT=FreeNAS
Nov 22 08:19:35 archive root: + NEW_AVATAR_PROJECT_SITE=http://www.freenas.org
Nov 22 08:19:35 archive root: + NEW_AVATAR_SUPPORT_SITE=http://support.freenas.org
Nov 22 08:19:35 archive root: + NEW_AVATAR_VERSION=9.1.1-RELEASE
Nov 22 08:19:35 archive root: + NEW_AVATAR_BUILD_NUMBER=a752d35
Nov 22 08:19:35 archive root: + NEW_AVATAR_ARCH=x64
Nov 22 08:19:35 archive root: + NEW_AVATAR_COMPONENT=os-base
Nov 22 08:19:35 archive root: + rc=0
Nov 22 08:19:35 archive root: + rm -f conf.zk1lgk
Nov 22 08:19:35 archive root: + source_conf //etc/avatar.conf OLD
Nov 22 08:19:35 archive root: + conffile=//etc/avatar.conf
Nov 22 08:19:35 archive root: + prefix=OLD
Nov 22 08:19:35 archive root: + [ ! -f //etc/avatar.conf -o -z OLD ]
Nov 22 08:19:35 archive root: + tmpconf=conf.UJXsI9
Nov 22 08:19:35 archive root: + sed -E -e 's/#.*//g' -e '/^[[:space:]]*$/d' -e '/^export /d' -e s/^/OLD_/g //etc/avatar.conf
Nov 22 08:19:35 archive root: + . conf.UJXsI9
Nov 22 08:19:35 archive root: + OLD_AVATAR_PROJECT=FreeNAS
Nov 22 08:19:35 archive root: + OLD_AVATAR_PROJECT_SITE=http://www.freenas.org
Nov 22 08:19:35 archive root: + OLD_AVATAR_SUPPORT_SITE=http://support.freenas.org
Nov 22 08:19:35 archive root: + OLD_AVATAR_VERSION=9.1.1-RC2
Nov 22 08:19:35 archive root: + OLD_AVATAR_BUILD_NUMBER=c7897fa
Nov 22 08:19:35 archive root: + OLD_AVATAR_ARCH=x64
Nov 22 08:19:35 archive root: + OLD_AVATAR_COMPONENT=os-base
Nov 22 08:19:35 archive root: + rm -f conf.UJXsI9
Nov 22 08:19:35 archive root: + mktemp install_worker.XXXXXX
Nov 22 08:19:35 archive root: + stage_log=install_worker.Dt9TlO
Nov 22 08:19:35 archive root: + ec=0
Nov 22 08:19:35 archive root: install_worker2.sh: INFO:: install_worker2.sh: INFO: sourcing pre-install/0001.prevent_downgrade.sh
Nov 22 08:19:35 archive root: install_worker2.sh: INFO:: install_worker2.sh: INFO: sourcing pre-install/0002.arch.sh
Nov 22 08:19:35 archive root: install_worker2.sh: INFO:: install_worker2.sh: INFO: sourcing pre-install/0003.project_switch.sh
Nov 22 08:19:35 archive root: install_worker2.sh: INFO:: install_worker2.sh: INFO: sourcing pre-install/0004.hardware_requirements.sh
Nov 22 08:19:35 archive root: + [ -s install_worker.Dt9TlO ]
Nov 22 08:19:35 archive root: + necho 'install_worker2.sh: pre-install summary'
Nov 22 08:19:35 archive root: + myecho INFO: 'install_worker2.sh: pre-install summary'
Nov 22 08:19:35 archive root: + local _type
Nov 22 08:19:35 archive root: + _type=INFO:
Nov 22 08:19:35 archive root: + echo 'install_worker2.sh: INFO:: install_worker2.sh: pre-install summary'
Nov 22 08:19:35 archive root: install_worker2.sh: INFO:: install_worker2.sh: pre-install summary
Nov 22 08:19:35 archive root: + cat install_worker.Dt9TlO
Nov 22 08:19:35 archive root: + find pre-install -name '*.sh'
Nov 22 08:19:35 archive root: + sort
Nov 22 08:19:35 archive root: + vecho 'install_worker2.sh: INFO: sourcing pre-install/0001.prevent_downgrade.sh'
Nov 22 08:19:35 archive root: + [ 1 != 0 ]
Nov 22 08:19:35 archive root: + myecho INFO: 'install_worker2.sh: INFO: sourcing pre-install/0001.prevent_downgrade.sh'
Nov 22 08:19:35 archive root: + echo 'install_worker2.sh: INFO:: install_worker2.sh: INFO: sourcing pre-install/0001.prevent_downgrade.sh'
Nov 22 08:19:35 archive root: + . pre-install/0001.prevent_downgrade.sh
Nov 22 08:19:35 archive root: + compare_version 9.1.1-RC2 9.1.1-RELEASE
Nov 22 08:19:35 archive root: + local version1 version2 unsorted sorted
Nov 22 08:19:35 archive root: + version1=9.1.1-RC2
Nov 22 08:19:35 archive root: + version2=9.1.1-RELEASE
Nov 22 08:19:35 archive root: + [ -z 9.1.1-RELEASE ]
Nov 22 08:19:35 archive root: + [ -z 9.1.1-RC2 ]
Nov 22 08:19:35 archive root: + [ 9.1.1-RC2 = 9.1.1-RELEASE ]
Nov 22 08:19:35 archive root: + rewrite_release_phases 9.1.1-RC2
Nov 22 08:19:35 archive root: + local i
Nov 22 08:19:35 archive root: + local version_string
Nov 22 08:19:35 archive root: + local version_string_old
Nov 22 08:19:35 archive root: + version_string=9.1.1-RC2
Nov 22 08:19:35 archive root: + version_string_old=9.1.1-RC2
Nov 22 08:19:35 archive root: + i=0
Nov 22 08:19:35 archive root: + set -- STABLE ALPHA BETA RC PRERELEASE RELEASE
Nov 22 08:19:35 archive root: + [ 6 -gt 0 ]
Nov 22 08:19:35 archive root: + echo 9.1.1-RC2
Nov 22 08:19:35 archive root: + sed -e s/STABLE/0./
Nov 22 08:19:35 archive root: + : 1
Nov 22 08:19:35 archive root: + [ 5 -gt 0 ]
Nov 22 08:19:35 archive root: + sed -e s/ALPHA/1./
Nov 22 08:19:35 archive root: + : 2
Nov 22 08:19:35 archive root: + [ 4 -gt 0 ]
Nov 22 08:19:35 archive root: + sed -e s/BETA/2./
Nov 22 08:19:35 archive root: + : 3
Nov 22 08:19:35 archive root: + [ 3 -gt 0 ]
Nov 22 08:19:35 archive root: + sed -e s/RC/3./
Nov 22 08:19:35 archive root: + version_string=9.1.1-3.2
Nov 22 08:19:35 archive root: + : 4
Nov 22 08:19:35 archive root: + [ 2 -gt 0 ]
Nov 22 08:19:35 archive root: + echo 9.1.1-3.2
Nov 22 08:19:35 archive root: + sed -e s/PRERELEASE/4./
Nov 22 08:19:35 archive root: + : 5
Nov 22 08:19:35 archive root: + [ 1 -gt 0 ]
Nov 22 08:19:35 archive root: + sed -e s/RELEASE/5./
Nov 22 08:19:35 archive root: + : 6
Nov 22 08:19:35 archive root: + [ 0 -gt 0 ]
Nov 22 08:19:35 archive root: + [ 9.1.1-3.2 = 9.1.1-RC2 ]
Nov 22 08:19:35 archive root: + version1=9.1.1-3.2
Nov 22 08:19:35 archive root: + rewrite_release_phases 9.1.1-RELEASE
Nov 22 08:19:35 archive root: + version_string=9.1.1-RELEASE
Nov 22 08:19:35 archive root: + version_string_old=9.1.1-RELEASE
Nov 22 08:19:35 archive root: + echo 9.1.1-RELEASE
Nov 22 08:19:35 archive root: + echo 9.1.1-5.
Nov 22 08:19:35 archive root: + echo -n 9.1.1-3.2 9.1.1-5.
Nov 22 08:19:35 archive root: + tr '\n' ' '
Nov 22 08:19:35 archive root: + return 1
Nov 22 08:19:35 archive root: + myecho INFO: 'install_worker2.sh: INFO: sourcing pre-install/0002.arch.sh'
Nov 22 08:19:35 archive root: + [ FreeNAS -a FreeNAS != FreeNAS ]
Nov 22 08:19:35 archive root: + vecho 'install_worker2.sh: INFO: sourcing pre-install/0004.hardware_requirements.sh'
Nov 22 08:19:35 archive root: + [ 0 -ne 0 ]
Nov 22 08:19:36 archive root: + return 0
Nov 22 08:19:36 archive root: + BLACKLIST_EXPR=''
Nov 22 08:19:36 archive root: + INSTALL_DESTDIR=/
Nov 22 08:19:36 archive root: + INSTALL_SRCDIR=/mnt/Archive_1/.freenas
Nov 22 08:19:36 archive root: + VERBOSE=1
Nov 22 08:19:36 archive root: + getopts D:f:m:v opt
Nov 22 08:19:36 archive root: + shift 0
Nov 22 08:19:36 archive root: + realpath /
Nov 22 08:19:36 archive root: + realpath /mnt/Archive_1/.freenas
Nov 22 08:19:36 archive root: + stage=install
Nov 22 08:19:36 archive root: + cd /mnt/Archive_1/.freenas
Nov 22 08:19:36 archive root: + [ -z install -o ! -d install -o 1 -ne 1 ]
Nov 22 08:19:36 archive root: + source_conf /mnt/Archive_1/.freenas/etc/avatar.conf NEW
Nov 22 08:19:36 archive root: + local IFS conffile prefix tmp
Nov 22 08:19:36 archive root: + conffile=/mnt/Archive_1/.freenas/etc/avatar.conf
Nov 22 08:19:36 archive root: + prefix=NEW
Nov 22 08:19:36 archive root: + [ ! -f /mnt/Archive_1/.freenas/etc/avatar.conf -o -z NEW ]
Nov 22 08:19:36 archive root: + mktemp conf.XXXXXX
Nov 22 08:19:36 archive root: + tmpconf=conf.uHiJMe
Nov 22 08:19:36 archive root: + sed -E -e 's/#.*//g' -e '/^[[:space:]]*$/d' -e '/^export /d' -e s/^/NEW_/g /mnt/Archive_1/.freenas/etc/avatar.conf
Nov 22 08:19:36 archive root: + . conf.uHiJMe
Nov 22 08:19:36 archive root: + NEW_AVATAR_PROJECT=FreeNAS
Nov 22 08:19:36 archive root: + NEW_AVATAR_PROJECT_SITE=http://www.freenas.org
Nov 22 08:19:36 archive root: + NEW_AVATAR_SUPPORT_SITE=http://support.freenas.org
Nov 22 08:19:36 archive root: + NEW_AVATAR_VERSION=9.1.1-RELEASE
Nov 22 08:19:36 archive root: + NEW_AVATAR_BUILD_NUMBER=a752d35
Nov 22 08:19:36 archive root: + NEW_AVATAR_ARCH=x64
Nov 22 08:19:36 archive root: + NEW_AVATAR_COMPONENT=os-base
Nov 22 08:19:36 archive root: + rc=0
Nov 22 08:19:36 archive root: + rm -f conf.uHiJMe
Nov 22 08:19:36 archive root: + source_conf //etc/avatar.conf OLD
Nov 22 08:19:36 archive root: + conffile=//etc/avatar.conf
Nov 22 08:19:36 archive root: + prefix=OLD
Nov 22 08:19:36 archive root: + [ ! -f //etc/avatar.conf -o -z OLD ]
Nov 22 08:19:36 archive root: + tmpconf=conf.rZo9Zd
Nov 22 08:19:36 archive root: + sed -E -e 's/#.*//g' -e '/^[[:space:]]*$/d' -e '/^export /d' -e s/^/OLD_/g //etc/avatar.conf
Nov 22 08:19:36 archive root: + . conf.rZo9Zd
Nov 22 08:19:36 archive root: + OLD_AVATAR_PROJECT=FreeNAS
Nov 22 08:19:36 archive root: + OLD_AVATAR_PROJECT_SITE=http://www.freenas.org
Nov 22 08:19:36 archive root: + OLD_AVATAR_SUPPORT_SITE=http://support.freenas.org
Nov 22 08:19:36 archive root: + OLD_AVATAR_VERSION=9.1.1-RC2
Nov 22 08:19:36 archive root: + OLD_AVATAR_BUILD_NUMBER=c7897fa
Nov 22 08:19:36 archive root: + OLD_AVATAR_ARCH=x64
Nov 22 08:19:36 archive root: + OLD_AVATAR_COMPONENT=os-base
Nov 22 08:19:36 archive root: + rm -f conf.rZo9Zd
Nov 22 08:19:36 archive root: + mktemp install_worker.XXXXXX
Nov 22 08:19:36 archive root: + stage_log=install_worker.EkKeAL
Nov 22 08:19:36 archive root: + ec=0
Nov 22 08:19:36 archive root: install_worker2.sh: INFO:: install_worker2.sh: INFO: sourcing install/0005.run_update.sh
Nov 22 08:27:00 archive root: ** /dev/da0s2a (NO WRITE)
Nov 22 08:27:00 archive root: ** Last Mounted on /tank/home/jkh/src/freenas/os-base/amd64/_.mnt
Nov 22 08:27:00 archive root: ** Phase 1 - Check Blocks and Sizes
Nov 22 08:27:00 archive root: ** Phase 2 - Check Pathnames
Nov 22 08:27:00 archive root: DIRECTORY CORRUPTED I=120768 OWNER=root MODE=40755
Nov 22 08:27:00 archive root: SIZE=512 MTIME=Aug 27 04:50 2013
Nov 22 08:27:00 archive root: DIR=?
Nov 22 08:27:00 archive root: UNEXPECTED SOFT UPDATE INCONSISTENCY
Nov 22 08:27:00 archive root: SALVAGE? no
Nov 22 08:27:00 archive root: MISSING '.' I=120768 OWNER=root MODE=40755
Nov 22 08:27:00 archive root: FIX? no
Nov 22 08:27:00 archive root: MISSING '..' I=120768 OWNER=root MODE=40755
Nov 22 08:27:00 archive root: DIR=/usr/local/lib/python2.7/site-packages/django/contrib/sites/locale/pa/LC_MESSAGES
Nov 22 08:27:00 archive root: ** Phase 3 - Check Connectivity
Nov 22 08:27:00 archive root: ** Phase 4 - Check Reference Counts
Nov 22 08:27:00 archive root: UNREF FILE I=120769 OWNER=root MODE=100644
Nov 22 08:27:00 archive root: SIZE=688 MTIME=Mar 9 09:37 2013
Nov 22 08:27:00 archive root: RECONNECT? no
Nov 22 08:27:00 archive root: CLEAR? no
Nov 22 08:27:00 archive root: ** Phase 5 - Check Cyl groups
Nov 22 08:27:00 archive root: 33776 files, 1340053 used, 557753 free (2145 frags, 69451 blocks, 0.1% fragmentation)
Nov 22 08:27:06 archive root: active set on da0s2
Nov 22 08:27:06 archive root: + [ -s install_worker.EkKeAL ]
Nov 22 08:27:06 archive root: + necho 'install_worker2.sh: install summary'
Nov 22 08:27:06 archive root: + myecho INFO: 'install_worker2.sh: install summary'
Nov 22 08:27:06 archive root: + local _type
Nov 22 08:27:06 archive root: + _type=INFO:
Nov 22 08:27:06 archive root: + shift
Nov 22 08:27:06 archive root: + echo 'install_worker2.sh: INFO:: install_worker2.sh: install summary'
Nov 22 08:27:06 archive root: install_worker2.sh: INFO:: install_worker2.sh: install summary
Nov 22 08:27:06 archive root: + cat install_worker.EkKeAL
Nov 22 08:27:06 archive root: + find install -name '*.sh'
Nov 22 08:27:06 archive root: + sort
Nov 22 08:27:06 archive root: + vecho 'install_worker2.sh: INFO: sourcing install/0005.run_update.sh'
Nov 22 08:27:06 archive root: + [ 1 != 0 ]
Nov 22 08:27:06 archive root: + myecho INFO: 'install_worker2.sh: INFO: sourcing install/0005.run_update.sh'
Nov 22 08:27:06 archive root: + echo 'install_worker2.sh: INFO:: install_worker2.sh: INFO: sourcing install/0005.run_update.sh'
Nov 22 08:27:06 archive root: + . install/0005.run_update.sh
Nov 22 08:27:06 archive root: + [ 1 != '' -a 1 != 0 ]
Nov 22 08:27:06 archive root: + sh -x /mnt/Archive_1/.freenas/bin/update /mnt/Archive_1/.freenas/firmware.img
Nov 22 08:27:06 archive root: + . /etc/nanobsd.conf
Nov 22 08:27:06 archive root: + NANO_DRIVE=ufs/FreeNAS
Nov 22 08:27:06 archive root: + dirname /mnt/Archive_1/.freenas/bin/update
Nov 22 08:27:06 archive root: + mydir=/mnt/Archive_1/.freenas/bin
Nov 22 08:27:06 archive root: + mount
Nov 22 08:27:06 archive root: + grep ufs/FreeNASs1
Nov 22 08:27:06 archive root: + exec sh -x /mnt/Archive_1/.freenas/bin/updatep2 /mnt/Archive_1/.freenas/firmware.img
Nov 22 08:27:06 archive root: + PARTNUM=2
Nov 22 08:27:06 archive root: + OTHER_PARTNUM=1
Nov 22 08:27:06 archive root: + set -e
Nov 22 08:27:06 archive root: + grep ufs/FreeNASs2
Nov 22 08:27:06 archive root: + echo ufs/FreeNAS
Nov 22 08:27:06 archive root: + cut -f2 -d/
Nov 22 08:27:06 archive root: + LABELNAME=FreeNAS
Nov 22 08:27:06 archive root: + glabel status
Nov 22 08:27:06 archive root: + awk '/ufs\/FreeNASs1a/ { print $3; }'
Nov 22 08:27:06 archive root: + sed -e s,s1a,,
Nov 22 08:27:06 archive root: + TARGET_DRIVE=da0
Nov 22 08:27:06 archive root: + dd if=/dev/zero of=/dev/da0s2 bs=1m count=1
Nov 22 08:27:06 archive root: + echo 28215
Nov 22 08:27:06 archive root: + dd if=/mnt/Archive_1/.freenas/firmware.img of=/dev/da0s2 obs=128k conv=sparse
Nov 22 08:27:06 archive root: + wait
Nov 22 08:27:06 archive root: + fsck_ffs -n /dev/da0s2a
Nov 22 08:27:06 archive root: + tunefs -L FreeNASs2a /dev/da0s2a
Nov 22 08:27:06 archive root: + mktemp -d /mnt/tmp.XXXXXX
Nov 22 08:27:06 archive root: + tmpdir=/mnt/tmp.m1HSis
Nov 22 08:27:06 archive root: + mount -o noatime /dev/da0s2a /mnt/tmp.m1HSis
Nov 22 08:27:06 archive root: + trap 'umount /mnt/tmp.m1HSis' 1 2 15 EXIT
Nov 22 08:27:06 archive root: + dirs='/root/.ssh /usr/local/fusion-io'
Nov 22 08:27:06 archive root: + [ -d /root/.ssh ]
Nov 22 08:27:06 archive root: + [ -d /usr/local/fusion-io ]
Nov 22 08:27:06 archive root: + umount /mnt/tmp.m1HSis
Nov 22 08:27:06 archive root: + mount -o noatime /dev/ufs/FreeNASs2a /mnt/tmp.m1HSis
Nov 22 08:27:06 archive root: + sed -i '' s,ufs/FreeNASs1,ufs/FreeNASs2, /mnt/tmp.m1HSis/conf/base/etc/fstab
Nov 22 08:27:06 archive root: + sed -i '' s,ufs/FreeNASs1,ufs/FreeNASs2, /mnt/tmp.m1HSis/etc/fstab
Nov 22 08:27:06 archive root: + trap - 1 2 15 EXIT
Nov 22 08:27:06 archive root: + gpart set -a active -i 2 da0
Nov 22 08:27:06 archive root: + saved_ec=0
Nov 22 08:27:06 archive root: + [ 0 -ne 0 ]
Nov 22 08:27:06 archive root: + rm -f install_worker.EkKeAL
Nov 22 08:27:06 archive root: + exit 0
Thanks
Chris
