I'm using the 6 motherboard ports from an ASUS M4A88T-M LE
the northbridge is a 880G, and the Southbridge is a SB710
With a 4 port Syba SATA controller SIL3124 chipset.
if the HBA is sata3, it should go. If you need also more performance with more capacity, consider to add another pair of mirror instead changing the drives.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
