When I upgraded to 11.3-U2, I encountered an alert indicating that the NETLOGON share connection check encountered the following message:
I found that someone else had encountered this issue on Reddit: https://www.reddit.com/r/freenas/comments/fwmhyj/freenas_113u2_now_available/fmpqb08/ and tried the suggested steps from anodos325 but found that deselecting the certificate in the UI did not actually clear the attribute in the
Attempt to connect to netlogon share failed with error: 'key_length'.
activedirectory.update WS API call. Even when I selected the tick to indicate no certificate, it would still send (what I would assume was) the ID for the previously selected certificate and prevent me from enabling the AD service with the same key_length error. I had to manually make my own calls to the API in order to set the field to null. I'm not sure if this is a bug with the verification or a bug in the way the GUI sets "null" for deselected dropdown boxes?
