Update storage and adding cache
Charlie86
I am running FreeNAS-11.1-U6.3 on old HP box with:
Intel(R) Core(TM) i5 CPU 650 @ 3.20GHz
16GB of RAM
5x3TB WD reds in RAIDZ.
Mikrotik router
HP gigabit switch
Clients are:
MacBook Pro for file sharing
iMac for file sharing
2x Win10 machine for file sharing
HP network scanner
2x Apple TV for Infuse (4k and FullHD movies)
Other things:
-Logitech Media server
-qbitorrent for torrents
Honestly most of the time in use is qbitorrent and playing movies on appleTV and macbook.
Problems:
-If I open folder with movies on Macbook it loads for ages. (I have currently used 84% of all my space. )
-I am out of space.
-out of sata connectors
Solution:
I have old DAS Lacie biggest Quadra but it only recognise 754GB of my 3TB drives. Idea was to fill it with 4x3TB new drives and connect it via eSata to FreeNas.
Due disks are not recognise by this old DAS, I need to connect new drives directly to FreeNas.
What sata/sas PCI card do you suggest? I would like some cheep solution :)
Second idea is about speeding up whole system. Should I add extra SSD for cache since RAM is already maxed out (16GB)? I have one 500GB SSD laying around and I could add it to FreeNas if I will bought sata pci card.
Thanks and have a nice day
You've looked at the hardware recommendations guide, right? Because it pretty clearly answers this question.
How is your ARC hit ratio? Though with only 16 GB of RAM, I wouldn't think that's a good idea in any event.
Charlie86
Charlie86
My system is now "upgraded".
I added IBM M1015 and few HDDs.
Now I have 9x3TB in RAIDZ1
It works fine for for watching movies on Apple TV. But I am still getting lots of problem accessing data via SMB or AFS. Access is ultra slow.
Sometimes it takes few minutes just to load all folders with movies (aprox 10TB).
I att you can fin my ZFS data.
Will there be any diference if I add 500GB cache SSD?
Unless this has changed since January, you need more RAM, not a L2ARC device.
