Dwarf Cavendish
- Dec 19, 2017
I just had a scary moment when I opened my email:
And an email from a few hours later:
Judging from the emails I received the error was reported as a result of the most recent scrub, that was run last night. The reboot cleared the warning about my pool.
Now about my system: I'm running TrueNAS-13.0-U4 on a HPE Microserver Gen10. The disks are two WD Red 4TB in a mirrorred vdev. I have been running since FreeNAS 11.1 and inherited legacy encryption from that (which makes me a bit scared of replacing the disk, due to the required rekey step, which I only practiced years back).
Now, as for the SMART output, first ada0:
And ada1:
I find these values tough to read, so I diffed them. Only Spin_Up_Time, Power_On_Hours and Load_Cycle_Count have slightly different values between the disks, which suggests that they're (close to) default values. Also none are marked as failed. All in all I'm inclined to say that the disks are fine and that I can consider this a friendly reminder that I should make sure that I got my back-ups in order (which I mostly do). I just kicked off another scrub to be sure, though.
Can anyone think of reasons to be more concerned, additional things to check perhaps? Thanks in advance for your thoughts
Pool mypool state is ONLINE: One or more devices has experienced an
unrecoverable error. An attempt was made to correct the error. Applications
are unaffected.
hostnameofmynas had an unscheduled system reboot. The operating system
successfully came back online at Sat Apr 8 12:07:35 2023
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p7 amd64] (local build)
Model Family: Western Digital Red
Device Model: WDC WD40EFRX-68N32N0
Serial Number: WD-WCC7K2ES26KD
LU WWN Device Id: 5 0014ee 2ba0434d8
Firmware Version: 82.00A82
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sat Apr 8 14:32:52 2023 CEST
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (45000) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 478) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 163 163 021 Pre-fail Always - 6833
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 112
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 041 041 000 Old_age Always - 43078
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 112
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 26
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 125
194 Temperature_Celsius 0x0022 126 108 000 Old_age Always - 24
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 42907 -
# 2 Extended offline Completed without error 00% 42500 -
# 3 Extended offline Completed without error 00% 42164 -
# 4 Extended offline Completed without error 00% 41828 -
# 5 Extended offline Completed without error 00% 41493 -
# 6 Extended offline Completed without error 00% 41085 -
# 7 Extended offline Completed without error 00% 40749 -
# 8 Extended offline Completed without error 00% 40342 -
# 9 Extended offline Completed without error 00% 40006 -
#10 Extended offline Completed without error 00% 39622 -
#11 Extended offline Completed without error 00% 39287 -
#12 Extended offline Completed without error 00% 38690 -
#13 Extended offline Completed without error 00% 38306 -
#14 Extended offline Completed without error 00% 38017 -
#15 Extended offline Completed without error 00% 37426 -
#16 Extended offline Completed without error 00% 37227 -
#17 Extended offline Completed without error 00% 36892 -
#18 Extended offline Completed without error 00% 36524 -
#19 Extended offline Completed without error 00% 36189 -
#20 Extended offline Completed without error 00% 35781 -
#21 Extended offline Completed without error 00% 35446 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
And ada1:
Serial Number: WD-WCC7K1XR4UJX
LU WWN Device Id: 5 0014ee 264ad66a2
Local Time is: Sat Apr 8 14:33:00 2023 CEST
was never started.
been run.
data collection: (44520) seconds.
command.
power-saving mode.
recommended polling time: ( 472) minutes.
3 Spin_Up_Time 0x0027 160 160 021 Pre-fail Always - 6958
9 Power_On_Hours 0x0032 041 041 000 Old_age Always - 43077
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 124
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 1
No Errors Logged
# 1 Extended offline Completed without error 00% 42906 -
# 2 Extended offline Completed without error 00% 42499 -
# 3 Extended offline Completed without error 00% 42163 -
# 5 Extended offline Completed without error 00% 41492 -
# 8 Extended offline Completed without error 00% 40341 -
#11 Extended offline Completed without error 00% 39286 -
#12 Extended offline Completed without error 00% 38689 -
#13 Extended offline Completed without error 00% 38305 -
#14 Extended offline Completed without error 00% 38016 -
#17 Extended offline Completed without error 00% 36891 -
#19 Extended offline Completed without error 00% 36188 -
#21 Extended offline Completed without error 00% 35445 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
