Limitedheadroom
- Aug 21, 2015
Hi, I've just increased the size of my pool by replacing all the drives one by one with larger drives. No sooner had I done this and I got the dreaded
I've never had to deal with this before so would appreciate a bit of guidance.
Checking zpool status I get the following
I can see one of the drives has 9 checksum errors and another had 23! none of these drives are more than 5 days old, and the one with 23 errors had literally just finished resilvering when the alert appeared.
I've run a long smart test on all drives and they all appear to pass. Here is the results for the drive with 23 errors. Again, I don't really know what most of this is telling me, but it says the drive passed.
My question is could this just be down to a loose cable or something from me fiddling about with drives and moving this, this appeared just as I was beginning the resilvering of the final drive. In which case, am I safe to run zpool clear and wait to see if anything pops up again?
Are there other checks I should do first?
Thank you
One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected.
pool: ChassPool1 state: ONLINE status: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected. action: Determine if the device needs to be replaced, and clear the errors using 'zpool clear' or replace the device with 'zpool replace'. see: http://illumos.org/msg/ZFS-8000-9P scan: scrub repaired 12K in 0 days 04:21:29 with 0 errors on Sun May 1 06:21:37 2022 config: NAME STATE READ WRITE CKSUM ChassPool1 ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 gptid/e1cd7ad2-c635-11ec-b7a1-d05099c3a27c ONLINE 0 0 0 gptid/16ebafcb-c6fb-11ec-991d-d05099c3a27c ONLINE 0 0 9 gptid/e471663b-bf1c-11ec-ba23-d05099c3a27c ONLINE 0 0 0 gptid/5deacf17-c023-11ec-9c6a-d05099c3a27c ONLINE 0 0 0 gptid/54c5a68c-c79e-11ec-8765-d05099c3a27c ONLINE 0 0 23 gptid/c4287624-c7f4-11ec-bc5f-d05099c3a27c ONLINE 0 0 0 errors: No known data errors pool: freenas-boot state: ONLINE scan: scrub repaired 0 in 0 days 00:08:07 with 0 errors on Thu Apr 28 03:53:07 2022 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 da0p2 ONLINE 0 0 0 da1p2 ONLINE 0 0 0 errors: No known data errors
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p7 amd64] (local build) Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: TOSHIBA HDWG480 Serial Number: 2260A0YSFA3H LU WWN Device Id: 5 000039 b78cae12a Firmware Version: 0601 User Capacity: 8,001,563,222,016 bytes [8.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Mon May 2 12:16:36 2022 BST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x80) Offline data collection activity was never started. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 120) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 681) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0 2 Throughput_Performance 0x0005 100 100 050 Pre-fail Offline - 0 3 Spin_Up_Time 0x0027 100 100 001 Pre-fail Always - 12318 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 3 5 Reallocated_Sector_Ct 0x0033 100 100 050 Pre-fail Always - 0 7 Seek_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0 8 Seek_Time_Performance 0x0005 100 100 050 Pre-fail Offline - 0 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 74 10 Spin_Retry_Count 0x0033 100 100 030 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 3 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 0 193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 3 194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 31 (Min/Max 14/35) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 220 Disk_Shift 0x0002 100 100 000 Old_age Always - 83886081 222 Loaded_Hours 0x0032 100 100 000 Old_age Always - 74 223 Load_Retry_Count 0x0032 100 100 000 Old_age Always - 0 224 Load_Friction 0x0022 100 100 000 Old_age Always - 0 226 Load-in_Time 0x0026 100 100 000 Old_age Always - 515 240 Head_Flying_Hours 0x0001 100 100 001 Pre-fail Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 69 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
Thank you
