Limitedheadroom
- Aug 21, 2015
Hi, I've just increased the size of my pool by replacing all the drives one by one with larger drives. No sooner had I done this and I got the dreaded
I've never had to deal with this before so would appreciate a bit of guidance.
Checking zpool status I get the following
I can see one of the drives has 9 checksum errors and another had 23! none of these drives are more than 5 days old, and the one with 23 errors had literally just finished resilvering when the alert appeared.
I've run a long smart test on all drives and they all appear to pass. Here is the results for the drive with 23 errors. Again, I don't really know what most of this is telling me, but it says the drive passed.
My question is could this just be down to a loose cable or something from me fiddling about with drives and moving this, this appeared just as I was beginning the resilvering of the final drive. In which case, am I safe to run zpool clear and wait to see if anything pops up again?
Are there other checks I should do first?
Thank you
One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.I've never had to deal with this before so would appreciate a bit of guidance.
pool: ChassPool1
state: ONLINE
status: One or more devices has experienced an unrecoverable error. An
see: http://illumos.org/msg/ZFS-8000-9P
scan: scrub repaired 12K in 0 days 04:21:29 with 0 errors on Sun May 1 06:21:37 2022
NAME STATE READ WRITE CKSUM
ChassPool1 ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/e1cd7ad2-c635-11ec-b7a1-d05099c3a27c ONLINE 0 0 0
gptid/16ebafcb-c6fb-11ec-991d-d05099c3a27c ONLINE 0 0 9
gptid/e471663b-bf1c-11ec-ba23-d05099c3a27c ONLINE 0 0 0
gptid/5deacf17-c023-11ec-9c6a-d05099c3a27c ONLINE 0 0 0
gptid/54c5a68c-c79e-11ec-8765-d05099c3a27c ONLINE 0 0 23
gptid/c4287624-c7f4-11ec-bc5f-d05099c3a27c ONLINE 0 0 0
errors: No known data errors
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:08:07 with 0 errors on Thu Apr 28 03:53:07 2022
freenas-boot ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
da0p2 ONLINE 0 0 0
da1p2 ONLINE 0 0 0
errors: No known data errorsI can see one of the drives has 9 checksum errors and another had 23! none of these drives are more than 5 days old, and the one with 23 errors had literally just finished resilvering when the alert appeared.
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p7 amd64] (local build)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model: TOSHIBA HDWG480
Serial Number: 2260A0YSFA3H
LU WWN Device Id: 5 000039 b78cae12a
Firmware Version: 0601
User Capacity: 8,001,563,222,016 bytes [8.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon May 2 12:16:36 2022 BST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x80) Offline data collection activity
was never started.
been run.
data collection: ( 120) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 681) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0
2 Throughput_Performance 0x0005 100 100 050 Pre-fail Offline - 0
3 Spin_Up_Time 0x0027 100 100 001 Pre-fail Always - 12318
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 3
5 Reallocated_Sector_Ct 0x0033 100 100 050 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 100 100 050 Pre-fail Offline - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 74
10 Spin_Retry_Count 0x0033 100 100 030 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 3
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 0
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 3
194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 31 (Min/Max 14/35)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
220 Disk_Shift 0x0002 100 100 000 Old_age Always - 83886081
222 Loaded_Hours 0x0032 100 100 000 Old_age Always - 74
223 Load_Retry_Count 0x0032 100 100 000 Old_age Always - 0
224 Load_Friction 0x0022 100 100 000 Old_age Always - 0
226 Load-in_Time 0x0026 100 100 000 Old_age Always - 515
240 Head_Flying_Hours 0x0001 100 100 001 Pre-fail Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 69 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.My question is could this just be down to a loose cable or something from me fiddling about with drives and moving this, this appeared just as I was beginning the resilvering of the final drive. In which case, am I safe to run zpool clear and wait to see if anything pops up again?
Thank you
