potatosword
- Dec 30, 2018
I just added a new encrypted Z2 pool to my server but alas, one of my drives turned out to be DoA. Got the pool up and running and left it degraded while waiting for the new drive to arrive. New drive gets here and I start the re-silvering process and I get the above error. I try it again, same error. I start researching and poking around FreeNAS and I see the little "resilvering" icon up top. I check and it's progressing through a resilver despite throwing an error earlier - no problem - I'll let it finish.
Somewhere around 80% resilver we got a series of write errors that sent ATA from 0 to 1. In response, I ran a SMART test that completed without error. Then sometime after I went to bed ATA went from 1 to 2. Thought strangely FreeNAS never reported this.
Now we seem to be scanning the resilver with an ever-growing time remaining. My gut feeling is that this is related to the original error that was thrown but what do I know.
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p9 amd64] (local build) Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Seagate Barracuda 2.5 5400 Device Model: ST2000LM015-2E8174 Serial Number: WDZ4CGA0 LU WWN Device Id: 5 000c50 0a9459904 Firmware Version: SDM1 User Capacity: 2,000,398,934,016 bytes [2.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 2.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-3 T13/2161-D revision 3b SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sat Jun 20 08:58:44 2020 CDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 0) seconds. Offline data collection capabilities: (0x71) SMART execute Offline immediate. No Auto Offline data collection support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 325) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x3035) SCT Status supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 074 067 006 Pre-fail Always - 23965580 3 Spin_Up_Time 0x0003 099 099 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 12 5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 066 060 045 Pre-fail Always - 3600148 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 19 (54 33 0) 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 10 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 061 051 040 Old_age Always - 39 (Min/Max 29/45) 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 1 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 1 193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 34 194 Temperature_Celsius 0x0022 039 049 000 Old_age Always - 39 (0 21 0 0 0) 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 18 (71 184 0) 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 686007324 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 70380573 254 Free_Fall_Sensor 0x0032 100 100 000 Old_age Always - 0 SMART Error Log Version: 1 ATA Error Count: 2 CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 2 occurred at disk power-on lifetime: 19 hours (0 days + 19 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 04 51 00 ff ff ff 0f Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ea 00 00 00 00 00 00 00 12:25:03.719 FLUSH CACHE EXT b0 d5 01 01 4f c2 00 00 12:22:17.834 SMART READ LOG b0 d5 01 06 4f c2 00 00 12:22:17.752 SMART READ LOG b0 d0 01 00 4f c2 00 00 12:22:17.637 SMART READ DATA b0 da 00 00 4f c2 00 00 12:22:17.579 SMART RETURN STATUS Error 1 occurred at disk power-on lifetime: 11 hours (0 days + 11 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 04 71 03 06 02 0c 40 Device Fault; Error: ABRT at LBA = 0x000c0206 = 786950 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 61 00 00 ff ff ff 4f 00 04:45:00.717 WRITE FPDMA QUEUED 61 00 00 ff ff ff 4f 00 04:45:00.717 WRITE FPDMA QUEUED 61 00 00 ff ff ff 4f 00 04:45:00.717 WRITE FPDMA QUEUED 61 00 00 ff ff ff 4f 00 04:45:00.717 WRITE FPDMA QUEUED 61 00 00 ff ff ff 4f 00 04:45:00.717 WRITE FPDMA QUEUED SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 17 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
