Charger_Replicat
 - Mar 27, 2023
Within the last week, the system has had a few unexpected reboots. The unexpected reboots usually happen when the system is not in use. The latest reboot happened in the middle of the night. I suspect this is a hardware issue. I know my hardware is not ideal for TrueNAS, but the system has been running for a year without any issues. I ran an extended SMART test with no issues found. Below is the output of dmesg:
			Copyright (c) 1992-2021 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 13.1-RELEASE-p7 n245428-4dfb91682c1 TRUENAS amd64
FreeBSD clang version 13.0.0 (git@github.com:llvm/llvm-project.git llvmorg-13.0.0-0-gd7b669b3a303)
VT(efifb): resolution 1024x768
CPU: Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz (3093.17-MHz K8-class CPU)
Origin="GenuineIntel" Id=0x206a7 Family=0x6 Model=0x2a Stepping=7
Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Features2=0x1d9ae3bf<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,POPCNT,TSCDLT,XSAVE,OSXSAVE,AVX>
AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM>
AMD Features2=0x1<LAHF>
XSAVE Features=0x1<XSAVEOPT>
VT-x: PAT,HLT,MTF,PAUSE,EPT,UG,VPID
TSC: P-state invariant, performance statistics
real memory = 17179869184 (16384 MB)
avail memory = 16580001792 (15811 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <ALASKA A M I>
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
FreeBSD/SMP: 1 package(s) x 2 core(s) x 2 hardware threads
random: unblocking device.
ioapic0 <Version 2.0> irqs 0-23
Launching APs: 1 2 3
random: entropy device external interface
kbd1 at kbdmux0
efirtc0: <EFI Realtime Clock>
efirtc0: registered as a time-of-day clock, resolution 1.000000s
aesni0: No AES or SHA support.
padlock0: No ACE support.
acpi0: <ALASKA A M I>
acpi0: Power Button (fixed)
cpu0: <ACPI CPU> on acpi0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 550
Event timer "HPET1" frequency 14318180 Hz quality 440
Event timer "HPET2" frequency 14318180 Hz quality 440
Event timer "HPET3" frequency 14318180 Hz quality 440
Event timer "HPET4" frequency 14318180 Hz quality 440
atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0
atrtc0: Warning: Couldn't map I/O.
atrtc0: registered as a time-of-day clock, resolution 1.000000s
Event timer "RTC" frequency 32768 Hz quality 0
attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> irq 16 at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
vgapci0: <VGA-compatible display> port 0xe000-0xe07f mem 0xf6000000-0xf6ffffff,0xe0000000-0xefffffff,0xf4000000-0xf5ffffff irq 16 at device 0.0 on pci1
vgapci0: Boot video device
pci0: <simple comms> at device 22.0 (no driver attached)
ehci0: <Intel Cougar Point USB 2.0 controller> mem 0xf7107000-0xf71073ff irq 16 at device 26.0 on pci0
usbus0: EHCI version 1.0
usbus0 on ehci0
usbus0: 480Mbps High Speed USB v2.0
pci0: <multimedia, HDA> at device 27.0 (no driver attached)
pcib2: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
pci2: <ACPI PCI bus> on pcib2
pcib3: <ACPI PCI-PCI bridge> irq 16 at device 28.4 on pci0
pci3: <ACPI PCI bus> on pcib3
re0: <RealTek 8168/8111 B/C/CP/D/DP/E/F/G PCIe Gigabit Ethernet> port 0xd000-0xd0ff mem 0xf0004000-0xf0004fff,0xf0000000-0xf0003fff irq 16 at device 0.0 on pci3
re0: Using 1 MSI-X message
re0: Chip rev. 0x2c800000
re0: MAC rev. 0x00100000
miibus0: <MII bus> on re0
rgephy0: <RTL8169S/8110S/8211 1000BASE-T media interface> PHY 1 on miibus0
rgephy0: none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
re0: Using defaults for TSO: 65518/35/2048
re0: Ethernet address: 90:2b:34:47:e2:2d
ehci1: <Intel Cougar Point USB 2.0 controller> mem 0xf7106000-0xf71063ff irq 23 at device 29.0 on pci0
usbus1: EHCI version 1.0
usbus1 on ehci1
usbus1: 480Mbps High Speed USB v2.0
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
atapci0: <Intel Cougar Point SATA600 controller> port 0xf0d0-0xf0d7,0xf0c0-0xf0c3,0xf0b0-0xf0b7,0xf0a0-0xf0a3,0xf090-0xf09f,0xf080-0xf08f irq 19 at device 31.2 on pci0
ata2: <ATA channel> at channel 0 on atapci0
ata3: <ATA channel> at channel 1 on atapci0
atapci1: <Intel Cougar Point SATA300 controller> port 0xf070-0xf077,0xf060-0xf063,0xf050-0xf057,0xf040-0xf043,0xf030-0xf03f,0xf020-0xf02f irq 19 at device 31.5 on pci0
ata4: <ATA channel> at channel 0 on atapci1
ata5: <ATA channel> at channel 1 on atapci1
acpi_button0: <Power Button> on acpi0
acpi_tz0: <Thermal Zone> on acpi0
acpi_tz1: <Thermal Zone> on acpi0
atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
ichwd0: <Intel Cougar Point watchdog timer> on isa0
ichwd0: ICH WDT present but disabled in BIOS or hardware
device_attach: ichwd0 attach returned 6
ichwd0: <Intel Cougar Point watchdog timer> at port 0x430-0x437,0x460-0x47f on isa0
superio0: <ITE IT8728 SuperIO (revision 0x01)> at port 0x2e-0x2f on isa0
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
est0: <Enhanced SpeedStep Frequency Control> on cpu0
Timecounter "TSC-low" frequency 1546486665 Hz quality 1000
Timecounters tick every 1.000 msec
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
ugen0.1: <Intel EHCI root HUB> at usbus0
ugen1.1: <Intel EHCI root HUB> at usbus1
uhub0 on usbus0
uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
uhub1 on usbus1
uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
Trying to mount root from zfs:boot-pool/ROOT/13.0-U5.1 []...
Root mount waiting for: usbus0 usbus1 CAM
uhub0: 2 ports with 2 removable, self powered
uhub1: 2 ports with 2 removable, self powered
ugen0.2: <vendor 0x8087 product 0x0024> at usbus0
uhub2 on uhub0
uhub2: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus0
ugen1.2: <vendor 0x8087 product 0x0024> at usbus1
uhub3 on uhub1
uhub3: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus1
uhub2: 4 ports with 4 removable, self powered
ada0 at ata2 bus 0 scbus0 target 0 lun 0
ada0: <Lexar 128GB SSD SN09610> ACS-4 ATA SATA 3.x device
ada0: Serial Number MBA717W100336
ada0: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 512bytes)
ada0: 122104MB (250069680 512 byte sectors)
ada1 at ata3 bus 0 scbus1 target 0 lun 0
ada1: <Lexar 128GB SSD SN09610> ACS-4 ATA SATA 3.x device
ada1: Serial Number MBA717W100329
ada1: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 512bytes)
ada1: 122104MB (250069680 512 byte sectors)
ada2 at ata4 bus 0 scbus2 target 0 lun 0
ada2: <WDC WD40EFZX-68AWUN0 81.00B81> ACS-3 ATA SATA 3.x device
ada2: Serial Number WD-WX22DC1K2ZXA
ada2: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes)
ada2: 3815447MB (7814037168 512 byte sectors)
ada3 at ata5 bus 0 scbus3 target 0 lun 0
ada3: <WDC WD40EFZX-68AWUN0 81.00B81> ACS-3 ATA SATA 3.x device
ada3: Serial Number WD-WX22DC1L3K8L
ada3: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes)
ada3: 3815447MB (7814037168 512 byte sectors)
uhub3: 6 ports with 6 removable, self powered
ugen0.3: <American Power Conversion Back-UPS RS 700G FW:856.L1 .D USB FW:L1> at usbus0
Waiting (max 60 seconds) for system process `vnlru' to stop... done
Waiting (max 60 seconds) for system process `syncer' to stop...
Syncing disks, vnodes remaining... 0 0 done
All buffers synced.
Uptime: 25s
re0: link state changed to UP
---<<BOOT>>---
CPU: Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz (3093.13-MHz K8-class CPU)
avail memory = 16580005888 (15811 MB)
kbd1 at kbdmux0
usbus0 on ehci0
usbus1 on ehci1
kbd0 at atkbd0
Timecounter "TSC-low" frequency 1546486667 Hz quality 1000
uhub0 on usbus0
uhub1 on usbus1
uhub2 on uhub0
uhub3 on uhub1
ichsmb0: <Intel Cougar Point SMBus controller> port 0xf000-0xf01f mem 0xf7105000-0xf71050ff irq 18 at device 31.3 on pci0
smbus0: <System Management Bus> on ichsmb0
lo0: link state changed to UP
GEOM_MIRROR: Device mirror/swap0 launched (2/2).
GEOM_MIRROR: Device mirror/swap1 launched (2/2).
GEOM_ELI: Device mirror/swap0.eli created.
GEOM_ELI: Encryption: AES-XTS 128
GEOM_ELI: Crypto: software
GEOM_ELI: Device mirror/swap1.eli created.
CPU: Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz (3092.97-MHz K8-class CPU)
Structured Extended Features3=0x9c000400<MD_CLEAR,IBPB,STIBP,L1DFL,SSBD>
re0: link state changed to DOWN
hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/4/48/0x3ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/3/48/0x67<INT,USR,SYS,REA,WRI>
Security policy loaded: MAC/ntpd (mac_ntpd)
epair0a: Ethernet address: 02:60:f2:ad:52:0a
epair0b: Ethernet address: 02:60:f2:ad:52:0b
epair0a: link state changed to UP
epair0b: link state changed to UP
epair0a: changing name to 'vnet0.1'
vnet0.1: link state changed to DOWN
epair0b: link state changed to DOWN
epair0a: Ethernet address: 02:fa:34:f3:95:0a
epair0b: Ethernet address: 02:fa:34:f3:95:0b
epair0a: changing name to 'vnet0.2'
vnet0.2: link state changed to DOWN
epair0a: Ethernet address: 02:d0:cb:a7:77:0a
epair0b: Ethernet address: 02:d0:cb:a7:77:0b
epair0a: changing name to 'vnet0.3'
vnet0.3: link state changed to DOWN
epair0a: Ethernet address: 02:a1:2f:78:f3:0a
epair0b: Ethernet address: 02:a1:2f:78:f3:0b
epair0a: changing name to 'vnet0.4'
panic: VERIFY3(0 == zap_remove_int(os, zfsvfs->z_unlinkedobj, zp->z_id, tx)) failed (0 == 2)
cpuid = 2
time = 1689318074
KDB: stack backtrace:
db_trace_self_wrapper() at db_trace_self_wrapper+0x2b/frame 0xfffffe01b7a4a7b0
vpanic() at vpanic+0x17f/frame 0xfffffe01b7a4a800
spl_panic() at spl_panic+0x3a/frame 0xfffffe01b7a4a860
zfs_rmnode() at zfs_rmnode+0x482/frame 0xfffffe01b7a4aa00
zfs_freebsd_reclaim() at zfs_freebsd_reclaim+0x38/frame 0xfffffe01b7a4aa30
VOP_RECLAIM_APV() at VOP_RECLAIM_APV+0x1f/frame 0xfffffe01b7a4aa50
vgonel() at vgonel+0x342/frame 0xfffffe01b7a4aac0
vrecycle() at vrecycle+0x40/frame 0xfffffe01b7a4aaf0
zfs_freebsd_inactive() at zfs_freebsd_inactive+0x53/frame 0xfffffe01b7a4ab30
vinactivef() at vinactivef+0xde/frame 0xfffffe01b7a4ab70
vput_final() at vput_final+0x26b/frame 0xfffffe01b7a4abc0
kern_statat() at kern_statat+0x186/frame 0xfffffe01b7a4ad00
sys_fstatat() at sys_fstatat+0x2f/frame 0xfffffe01b7a4ae00
amd64_syscall() at amd64_syscall+0x10c/frame 0xfffffe01b7a4af30
fast_syscall_common() at fast_syscall_common+0xf8/frame 0xfffffe01b7a4af30
--- syscall (552, FreeBSD ELF64, sys_fstatat), rip = 0x8011ad39a, rsp = 0x7fffffffe6f8, rbp = 0x7fffffffe810 ---
KDB: enter: panic
---<<BOOT>>---
CPU: Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz (3093.10-MHz K8-class CPU)
kbd1 at kbdmux0
usbus0 on ehci0
usbus1 on ehci1
kbd0 at atkbd0
Timecounter "TSC-low" frequency 1546486747 Hz quality 1000
uhub0 on usbus0
uhub1 on usbus1
uhub2 on uhub1
uhub2: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus1
uhub3 on uhub0
uhub3: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus0
uhub3: 4 ports with 4 removable, self powered
uhub2: 6 ports with 6 removable, self powered
kbd1 at kbdmux0
usbus0 on ehci0
usbus1 on ehci1
kbd0 at atkbd0
uhub0 on usbus0
uhub1 on usbus1
uhub2 on uhub0
uhub3 on uhub1
All buffers synced.
Uptime: 25s
---<<BOOT>>---
kbd1 at kbdmux0
usbus0 on ehci0
usbus1 on ehci1
kbd0 at atkbd0
uhub0 on usbus0
uhub1 on usbus1
uhub2 on uhub0
uhub3 on uhub1
cpuid = 2
time = 1689318074
KDB: enter: panic
---<<BOOT>>---
kbd1 at kbdmux0
usbus0 on ehci0
usbus1 on ehci1
kbd0 at atkbd0
uhub0 on usbus0
uhub1 on usbus1
uhub2 on uhub1
uhub3 on uhub0
