Under the Applications view, what does "Unset Pool" do?
Sawtaytoes
There's no documentation about this setting:
I was wanting to rename the zpool I'm using for apps, but I'm not sure how. I figured I'd offline the pool and bring it back up with a new name, but "Unset Pool" sounds like something different.
It seems clear to me...
When you have a new TrueNAS server with no pool set for Apps... you need to set a pool, so it has one.
Unset would be the opposite of that action, returning you the the point where you have no pool set for Apps.
Sawtaytoes
I tested this out. If I unset the pool, it goes away. When I set it back to that set of drives, it brings back all the apps.
In the past, I got an error about "this dataset xi-applications already exists", but that didn't happen if I first unset the Applications pool.
