Uncorrectable Parity/CRC Error ??
marcevan
Tested in a manner of speaking:
1. In old mobo/RAM/power got same errors even after swapping in new cables.
2. Got new mobo/RAM/power and keep seeing recurrance of the error on the console as an ada2 error.
3. Smartctl gives no issues with ada2 (or ada0, ada1, ada3, ada5).
4. Smartctl gives issue with ada4 posted above.
So on console I get the retrying and keep seeing that error ever 10 min or so, but overall freenas says pool is healthy and drive view shows same.
Errors continue to show in console and in daily emails.
Yatti420
I mean did you do ram testing / hard disk drive testing / visual inspections of all gear.. Capacitors etc.. As cyberjock noted earlier temps are high but not extreme.. I certainly wouldn't trust those drives/systems until you stop seeing those errors.. Maybe reseat both ends of ada4 again.. or give it a new cable again... Other then that I'd be back to testing..
marcevan
Did Prime test for 24 hrs, and RAM passed and was installed.
I typically don't test drives that go into RAID as I rely on RAID software to inform me.
In this case we have a difference of opinion between freeNAS pool/disk reporting and SMART showing an issue.
Yatti420
So is the motherboard set to RAID instead of AHCI?
marcevan
Mobo is set to AHCI. RAID is handled by freeNAS using Sun's ZFS technology for software RAID. However, the issue is that nothing in FreeNAS pool status or disk status shows any issue while console (which I believe is freeBSD's) does show the error on ADA2 while smartctl says it's on ADA4.
Ugh as the console will keep repeating:
Jan 21 17:15:08 freenas kernel: (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 c8 a0 15 8f 40 2e 00 00 00 00 00
Jan 21 17:15:08 freenas kernel: (ada2:ahcich2:0:0:0): CAM status: Uncorrectable parity/CRC error
Jan 21 17:15:08 freenas kernel: (ada2:ahcich2:0:0:0): Retrying command
gpsguy
Active Member
Please re-run: smartctl -a /dev/ada2 and post all the output in code tags, like you did for ada4.
It appears that you've never run any smart tests (short or long) on ada2.
marcevan
I ran long and short tests on all disks, but only ADA4 had issues. Here's smartctl -a /dev/ada2:
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Western Digital Red (AF)
Device Model:     WDC WD30EFRX-68EUZN0
Serial Number:    WD-WMC4N0329356
LU WWN Device Id: 5 0014ee 003a8ce01
Firmware Version: 80.00A80
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed Jan 22 09:41:23 2014 EST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (40680) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 408) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x703d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   201   201   021    Pre-fail  Always       -       4908
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       11
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   097   097   000    Old_age   Always       -       2611
 10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       11
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       8
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       2
194 Temperature_Celsius     0x0022   108   104   000    Old_age   Always       -       42
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   100   253   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
gpsguy
Active Member
According to line 83 (for ada2), you've never run any tests on this drive.
marcevan
Never said I prestressed drives... Only RAM with Prime. I have done the same smartctl on that and the other drives.
More to the point is the above anything related to the console messages about ADA2.
Exactly. Back on page 2 you'll see DrKK's comment about how I asked for the output and I got a watered down filtered and the response was something like "nothing notable to mention".
This is precisely why I don't want people interpreting what I ask for. Give me what I want or I leave. Because 90% of the time if you are asking for help you probably don't have the necessary knowledge to actually come to the conclusion that "nothing notable was seen". Now we've been told tests were run and passed, yet it's completely obvious no test was run, ever. Even if the test had been interrupted those are also logged appropriately.
And now we go back to what you said..
So have you figured out that there IS a reason why the developers include the SMART testing, SMART monitoring, and SMART reporting via email? That stuff you are choosing to ignore is actually VERY valuable and VERY useful. It tells you things ZFS and scrubs can't tell you.
Sorry if I sound snarky. I get really pissed when people water down what I ask for with their own interpretations and/or try to argue why SMART is a waste of time. It's super important! It may be the single most important thing you can use to monitor, test, and report disk health.
Of course, I do also enjoy people like you because when you need data recovery you have me or other services like Ontrack. And since the other people are more than 1 magnitude higher in cost I do enjoy the extra money from time to time. So guess who gets to earn a little money on the side when you lose your pool? :D
marcevan
No worries on sounding snarky. I get it. And I and surely dozens more appreciate your input on this board.
What I meant to imply was that when I keep seeing console errors for ADA2, I start fresh doing smartctl against ada0, ada1, ada2, etc. As ADA0, ADA1, ADA2, ADA3, ADA5 were all no errors I meant to say nothing startling there while ADA4 gave an explicit error which is odd (console says ADA2, smartctl says ADA4). This just points to a disparity in console reporting vs UNIX command reporting.
And at this point freeNAS says no issue in either pool health in gui or command line zpool status. The GUI shows all drives are fine as well. This just points to a disparity in freeNAS ability to inform on disk issues.
At this point I'm contemplating getting 2 new drives and for ADA4 and ADA2 and raidz2 should support that and resilver slowly. I'll probably be pulling one drive at a time starting with ADA4.
So I think I should clarify a few things...
If the console says ada2 is having problems, you can be assured that ada2 is having problems. Now, some people have gone off and thought other disks were bad due to crosstalk on cables. They'll disconnect ada3 and the ada2 problems will go away. So they'll assume that ada3 is the problem and the error reporting is wrong. So you need to take ALL of your data together to get the right answer. Since you are getting errors on ada2 and ada4 they are DEFINITELY having problems. The difference is whether ada2 is having problems or is the problem. There's a difference. And this is something you'll have to figure out with process of elimination.
ZFS simply reports on errors it finds via checksums, disk read errors, or disk write errors. That's all it can do. You want more, use SMART. That's what its there to do!
You should just stop and run SMART tests on all of your disks and see what they report.
marcevan
I'll RMA ADA2 to WD and get the replacement.
If that goes swimmingly I'll do the same on ADA4.
I'd rather replace one at a time in a RAIDz2 even though it can support 2 drives failing.
You do realize WD doesn't do RMAs without some kind of assurance there is a problem. And SMART tests will tell you that...
That is exactly why I said to stop and run SMART tests. You'll probably be upset if you RMA 2 good disks and the problem remains....
marcevan
I've worked with WD over the past several years, and their online RMA process allow for some freeform explanation after they validate the S/N of the drive(s).
That said, ADA4 reports a tangible error from SMART that will pass the RMA process; then upon replacement drive being cold-replaced I'll just see what I see from console/SMART regarding ADA2.
marcevan
So got the RMA in for ADA4 which had the smartctl error and also bought a new WD 3TB red drive to replace that.
So now it's resilvering and smartctl -a /dev/ada4 gives no errors. Monday I send back the replaced/RMA drive and then when I receive the new drive from them it goes in place of ADA2 which I'll be RMAing as well next week (that one with the continuous console errors)
