I had the community version of Zerotier installed and because of your recommendations I switched to the Truecharts version. I also had the problem with the community version that when the computer restarted it lost connectivity. I managed to install the charts catalog and everything seemed fine. The problem is that when I try to install zerotier (charts) I get the following error, with the community version it installed fine and except for the reboot problem everything worked fine. Any idea what I am doing wrong or what is missing on my side. TIA
Error:
Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/job.py", line 428, in run await self.future File "/usr/lib/python3/dist-packages/middlewared/job.py", line 463, in __run_body rv = await self.method(*([self] + args)) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1246, in nf res = await f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1378, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/chart_release.py", line 486, in do_create await self.middleware.call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1395, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1355, in _call return await self.run_in_executor(prepared_call.executor, methodobj, *prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1258, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run result = self.fn(*self.args, **self.kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/helm.py", line 44, in helm_action raise CallError(f'Failed to {tn_action} chart release: {stderr.decode()}') middlewared.service_exception.CallError: [EFAULT] Failed to install chart release: Error: INSTALLATION FAILED: failed pre-install: timed out waiting for the condition
