PhiloEpisteme
 - Oct 18, 2018
Hi folks,
The relevant systems are as follows
Primary
FreeNAS: 11.2-U6
Pool 1: crypt
Pool 2: vault
Board: X11SSM-F
WebGUI IP: 192.168.77.250 via onboard NIC
WebGUI Port: 1970
NIC: Chelsio T520-CR direct-connected to backup on 192.168.77.250/24
FreeNAS: 11.2-U6
Backup
FreeNAS: 11.2-U6
Pool 1: vault1
Board: X9SCM-F
WebGUI IP: 192.168.77.150 via onboard NIC
WebGUI Port: 4309
NIC: Chelsio T520-CR direct-connected to primary on 192.168.77.150/24
SSH IP: 192.168.14.150
SSH Port: 31892
Very recently I had to replace every drive in the vault pool. I performed the steps as follows. I had a strange work requirement such that resilvering each drive 1 by 1 was a non-option.
When I click "Scan SSH Key" I get the following error
I've tried looking at
I have tried to SSH to the other machine and it works whether I use the onboard NIC or the chelsio NIC.
So, I'm a bit stumped; I'm not sure what else to try.
Oddly enough, the replication task for crypt seems to still be working and running without any changes required.
Primary
FreeNAS: 11.2-U6
Pool 1: crypt
Pool 2: vault
Board: X11SSM-F
WebGUI Port: 1970
FreeNAS: 11.2-U6
Backup
FreeNAS: 11.2-U6
Pool 1: vault1
Board: X9SCM-F
WebGUI Port: 4309
SSH Port: 31892
- created the new pool tmpVault
 - created a manual recursive snapshot and performed replication between the pools from the command line to copy the data over
 - saved a copy of the system config
 - exported both pools through the GUI and destroyed configs for the pools but not the data
 - imported them manually and changed the names via
zpool import tmpVault vault; zpool import vault tmpVault - exported them again via CLI
 - imported both from the GUI
 - restored my system config
- Pool: vault
 - Remote ZFS Pool: vault1
 - Recursively Replicate Child Dataset Snapshots: checked
 - Delete Stale Snapshots on Remote System: checked
 - Replication Stream Compression: lz4
 - Limit: 0
 - Begin Time: 00:00
 - End Time: 23:59
 - Enabled: checked
 - Setup-Mode: semi-automatic
 - Remote Hostname: 192.168.14.150
 - Remote HTTP Port: 4309
 - Remote HTTPS: not checked
 - Remote Auth Token: Copied from other machine
 - Encryption cypher: standard
 - Dedicated User Enabled: not checked
 - Dedicated User: empty
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 165, in call_method
    result = await self.middleware.call_method(self, message)
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1096, in call_method
    return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1044, in _call
    return await methodobj(*args)
  File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 664, in nf
  File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/replication.py", line 307, in ssh_keyscan
    raise CallError(errmsg)
middlewared.service_exception.CallError: [EFAULT] ssh key scan failed for unknown reason
"/usr/local/lib/python3.6/site-packages/middlewared/plugins/replication.py", line 307 and find this. I then tried to run the command manually and got an error initially. Unfortunately I cannot reproduce this error and cannot post it; but it was something related to unknown host. If I try it now I get no error but no response either. $ /usr/bin/ssh-keyscan -p 4309 -T 2 192.168.14.150.I have tried to SSH to the other machine and it works whether I use the onboard NIC or the chelsio NIC.
ssh -i /data/ssh/replication -p 31892 192.168.77.150 and ssh -i /data/ssh/replication -p 31892 192.168.14.150 both work; though I tried the .14.150 address first and had to accept the new key and then 77.150 failed because the key changed so I deleted the key for 192.168.77.150 in /ect/.ssh/known_hosts and tried again and it worked.So, I'm a bit stumped; I'm not sure what else to try.
