Unable to install transmission
aimoo
I recently tried to deploy transmission via docker, but I keep getting the following error, I'm a rookie, I'm very troubled by this error and can't find where the problem is, so I registered an account to ask if you know how to solve this problem, any help would be appreciated!
2023-05-10 12:39:20.962960+00:00[migrations] started
2023-05-10 12:39:20.963006+00:00[migrations] no migrations found
2023-05-10 12:39:25.639504+00:00───────────────────────────────────────
2023-05-10 12:39:25.639594+00:002023-05-10T12:39:25.639594557Z
2023-05-10 12:39:25.639625+00:00██╗ ███████╗██╗ ██████╗
2023-05-10 12:39:25.639690+00:00██║ ██╔════╝██║██╔═══██╗
2023-05-10 12:39:25.639729+00:00██║ ███████╗██║██║ ██║
2023-05-10 12:39:25.639750+00:00██║ ╚════██║██║██║ ██║
2023-05-10 12:39:25.639785+00:00███████╗███████║██║╚██████╔╝
2023-05-10 12:39:25.639805+00:00╚══════╝╚══════╝╚═╝ ╚═════╝
2023-05-10 12:39:25.639823+00:002023-05-10T12:39:25.639823999Z
2023-05-10 12:39:25.639841+00:00Brought to you by linuxserver.io
2023-05-10 12:39:25.639859+00:00───────────────────────────────────────
2023-05-10 12:39:25.640339+00:002023-05-10T12:39:25.640339010Z
2023-05-10 12:39:25.640415+00:00To support LSIO projects visit:
2023-05-10 12:39:25.640439+00:00https://www.linuxserver.io/donate/
2023-05-10 12:39:25.640458+00:002023-05-10T12:39:25.640458472Z
2023-05-10 12:39:25.640518+00:00───────────────────────────────────────
2023-05-10 12:39:25.640541+00:00GID/UID
2023-05-10 12:39:25.640560+00:00───────────────────────────────────────
2023-05-10 12:39:25.643380+00:002023-05-10T12:39:25.643380764Z
2023-05-10 12:39:25.643396+00:00User UID: 1000
2023-05-10 12:39:25.643400+00:00User GID: 1000
2023-05-10 12:39:25.643404+00:00───────────────────────────────────────
2023-05-10 12:39:25.643408+00:002023-05-10T12:39:25.643408015Z
2023-05-10 12:39:26.160086+00:00# do daily/weekly/monthly maintenance
2023-05-10 12:39:26.160201+00:00# min hour day month weekday command
2023-05-10 12:39:26.160227+00:00*/15 * * * * run-parts /etc/periodic/15min
2023-05-10 12:39:26.160246+00:000 * * * * run-parts /etc/periodic/hourly
2023-05-10 12:39:26.160263+00:000 2 * * * run-parts /etc/periodic/daily
2023-05-10 12:39:26.160294+00:000 3 * * 6 run-parts /etc/periodic/weekly
2023-05-10 12:39:26.160313+00:000 5 1 * * run-parts /etc/periodic/monthly
2023-05-10 12:39:26.160331+00:002023-05-10T12:39:26.160331374Z
2023-05-10 12:39:26.160348+00:00# run daily blocklist update
2023-05-10 12:39:26.160378+00:000 3 * * * /app/blocklist-update.sh 2>&1
2023-05-10 12:39:26.388884+00:00[custom-init] No custom files found, skipping...
2023-05-10 12:39:30.546282+00:00[ls.io-init] done.
the following error
I see no error in your post. Did you miss something?
Do you want to remove the app config (since it contains your password)?
aimoo
I was trying to deploy transmissions, but I couldn't open them after deployment, so I I think 2023-05-10 12:39:26.388884+00:00[custom-init] No custom files found, skipping...
2023-05-10 12:39:30.546282+00:00[ls.io-init] done. is it reporting an error? If so
Thank you for the reminder, do not need to delete, in fact I have not been able to successfully use, the password is generated randomly through the password manager
And you're not able to connect to the web interface to check that it is or isn't working?
Yes, 1.1.1.1:9091, unable to connect
I'm not sure why you think that's the address of the container... it can't be that (that's cloudflare's DNS).
Well, no it isn't either...
Your config specifies to use a different IP and to get that from DHCP, so you need to check your DHCP server for that address.
aimoo
Oh my god, I managed to run it by removing the network configuration, thank you very much for your help !!!!
