Same Error
TrueNAS-SCALE-23.10.2
Disk: Exos 18TBx1
Error says:
Error: concurrent.futures.process._RemoteTraceback: """ Traceback (most recent call last):  File "/usr/lib/python3.11/concurrent/futures/process.py", line 256, in _process_worker    r = call_item.fn(*call_item.args, **call_item.kwargs)        ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^  File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 112, in main_worker    res = MIDDLEWARE._run(*call_args)          ^^^^^^^^^^^^^^^^^^^^^^^^^^^  File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 46, in _run    return self._call(name, serviceobj, methodobj, args, job=job)           ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^  File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 34, in _call    with Client(f'ws+unix://{MIDDLEWARE_RUN_DIR}/middlewared-internal.sock', py_exceptions=True) as c:  File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 40, in _call    return methodobj(*params)           ^^^^^^^^^^^^^^^^^^  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 181, in nf    return func(*args, **kwargs)           ^^^^^^^^^^^^^^^^^^^^^  File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs_/pool_actions.py", line 207, in import_pool    with libzfs.ZFS() as zfs:  File "libzfs.pyx", line 529, in libzfs.ZFS.__exit__  File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs_/pool_actions.py", line 227, in import_pool    zfs.import_pool(found, pool_name, properties, missing_log=missing_log, any_host=any_host)  File "libzfs.pyx", line 1369, in libzfs.ZFS.import_pool  File "libzfs.pyx", line 1397, in libzfs.ZFS.__import_pool  File "libzfs.pyx", line 658, in libzfs.ZFS.get_error  File "/usr/lib/python3.11/enum.py", line 717, in __call__    return cls.__new__(cls, value)           ^^^^^^^^^^^^^^^^^^^^^^^  File "/usr/lib/python3.11/enum.py", line 1133, in __new__    raise ve_exc ValueError: 2095 is not a valid Error """ The above exception was the direct cause of the following exception: Traceback (most recent call last):  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 427, in run    await self.future  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 465, in __run_body    rv = await self.method(*([self] + args))         ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 177, in nf    return await func(*args, **kwargs)           ^^^^^^^^^^^^^^^^^^^^^^^^^^^  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 44, in nf    res = await f(*args, **kwargs)          ^^^^^^^^^^^^^^^^^^^^^^^^  File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/import_pool.py", line 113, in import_pool    await self.middleware.call('zfs.pool.import_pool', guid, opts, any_host, use_cachefile, new_name)  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1399, in call    return await self._call(           ^^^^^^^^^^^^^^^^^  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1350, in _call    return await self._call_worker(name, *prepared_call.args)           ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1356, in _call_worker    return await self.run_in_proc(main_worker, name, args, job)           ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1267, in run_in_proc    return await self.run_in_executor(self.__procpool, method, *args, **kwargs)           ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1251, in run_in_executor    return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs))           ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ValueError: 2095 is not a valid Error
