s2604972172
- Jan 30, 2023
Hi everyone
I got an issue with creating stripe pool with my PCIe SSD. I'm using Micron P420m 1.4T HHHL PCIe SSD. The SSD is working I've used on my windows before. After install this SSD into my server and passthrough through Proxmox, I tried to create a stripe pool, it showed the following error.
[EFAULT] Partition type 6a898cc3-1dd2-11b2-99a6-080020736631 not found on rssda
I searched in the forums there is one got same problem as me, but the solution just won't work on my server. I'm not sure what was the issue right now.
www.truenas.com
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 426, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 461, in __run_body
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1152, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1284, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool.py", line 764, in do_create
await self.middleware.call('pool.format_disks', job, disks)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1306, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1255, in _call
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/format_disks.py", line 33, in format_disks
await asyncio_map(format_disk, disks.items(), limit=16)
File "/usr/lib/python3/dist-packages/middlewared/utils/asyncio_.py", line 16, in asyncio_map
return await asyncio.gather(*futures)
File "/usr/lib/python3/dist-packages/middlewared/utils/asyncio_.py", line 13, in func
return await real_func(arg)
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/format_disks.py", line 26, in format_disk
devname = await self.middleware.call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1266, in _call
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1169, in run_in_executor
File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/disk_/disk_info.py", line 93, in gptid_from_part_type
raise CallError(f'Partition type {part_type} not found on {disk}')
middlewared.service_exception.CallError: [EFAULT] Partition type 6a898cc3-1dd2-11b2-99a6-080020736631 not found on rssda
SOLVED - Unable to Create Stripe Pool with One NVMe AIC
Hello all! Taking SCALE out for a spin and encountered a big blocker: unable to create a stripe pool from one NVMe SSD (Samsung PM1735). As a test, a 80mm NVMe card SSD (970 Evo) was used in the same test (creating a stripe pool with the single drive) and it works with the 970 Evo, but failed...
