- Mar 6, 2014
[EDIT] As I mentioned before, it was working again. But then I got a lot of problems with the system, and needed to reinstall. And since the clean install it doesn't work anymore (again). [/EDIT]
Thanks, I tried this, but I must be doing something wrong.
I setup two shares pointing to the same dataset containing the music.
1. (the share for the sonos system)
path: /mnt/nas/music
browsable to network cliënts: selected
allow guest access: selected
only allow guest access: selected
hosts allow: 192.168.2.12 (this is the IP of my sonos bridge)
2. (the normal share)
But sadly it still wo'nt connect.
How do I enable/disable SMB1 NTLMv1? And is this done on the share level, or should I look at the storage tab?
Are there settings I should change to setup the guest account? Because at the moment it points to "nobody"
By the way, might this be solved by upgrading to FreeNas 11 ?
In FreeNAS 9.10.2-U5, you can add the "auxiliary parameter"
ntlm auth = yes
under services->smb. In FreeNAS 11 there's a checkbox that does that for you.
