Umount USB drive via gui?
operator
how to umount imported usb drive from the freenas 11.2u via GUI? I can't find the option.
Samuel Tai
Once the import is complete, you can just pull the USB drive. According to the 11.2-U8 Guide, Section 9.6:
The Pool ➞ Import Disk screen, shown in Figure 9.6.1, is used to import disks that are formatted with UFS (BSD Unix), FAT(MSDOS) or NTFS (Windows), or EXT2 (Linux) filesystems. This is a designed to be used as a one-time import, copying the data from that disk into a dataset on the FreeNAS® system. Only one disk can be imported at a time.​
Use the drop-down menu to select the disk to import, select the type of filesystem on the disk, and browse to the ZFS dataset that will hold the copied data. If the MSDOSFS filesystem is selected, an additional MSDOSFS locale drop-down menu will display. Use this menu to select the locale if non-ASCII characters are present on thedisk.​
After clicking SAVE, the disk is mounted and its contents are copied to the specified dataset. The disk is unmounted after the copy operation completes.​
Since the disk is unmounted when the import completes, you can just remove the USB drive.
