Dirk
- May 23, 2016
Decided to re task the old server and split up the work with Movies on one and tv-shows on the other. Server 1 (the newer server in my sig) running fine for weeks. Today work was to install Sonarr and Sab. Things have progressed downhill with things like opening a shell in the jails > sonarr resulting in a blank unresponsive terminal. I've repeatedly on both machines been met with "make sure the machine is turned on" or some such when I should get a login screen which I found I can get past by going into Firefox and "about:support" and doing a "clear startup cache"
Where it has gotten weird for me is that the new server was stuck at the "make sure the machine is powered on" and I was working with the other one and decided to power it down. The other server immediately went to a login screen when it was out of the way. Lastly BOTH machines are exhibiting the blank shell/console that is unresponsive if both machines are running
So, many things saying the two machines are fighting each other. If it matters, I can SSH in and iocage console jailname with no problem.
As always, thanks to the community for your help.
