Two Checksum errors on each and every drive after a resilver and replace. What to do ?
10Gauge
2 Checksum errors on all of the drives after a resilver and replace >
My SMB shares are working, but on the dashboard, Pool Status shows 'degraded', yet all drives show 'Online'
errors: Permanent errors have been detected in the following files: V4TBx8R2/.system/rrd-d968e280827d4008b5065e3ef738a9cd:<0x3eb>
Move your system dataset to your boot pool and back again (that should deal with the corrupt file).
Then run a zpool clear on that pool
10Gauge
Thanks so much for taking the time to reply. I have looked, but cannot seem to find a procedural to do that move. Can you point me to one, or explain to me in more detail ?
System Settings | Advanced.
In the box labeled Storage | Configure.
Pick the boot pool instead of the pool shown.
Save, then give it a little time (optionally a reboot), then back to the same place and set it back (after doing zpool clear).
10Gauge
Found it. Seems it had been moved to Settings > Advanced. So all I do is toggle it to boot and then back ?
See my post above where I already mentioned what to do.
10Gauge
Yes, Thanks, I posted just before your reply. Can I assume that you meant System Dataset | Configure ?
10Gauge
You may need to reboot to free that up then.
10Gauge
Yes, I did the clear. Just repeated it. No Joy.
I have full SMB access and it appears to be working properly. Just shows the error on the dashboard. FWIW.
root@truenas[~]# zpool status
pool: V4TBx8R2
state: ONLINE
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A
scan: resilvered 17.5M in 00:00:19 with 2 errors on Mon Aug 7 13:24:54 2023
NAME STATE READ WRITE CKSUM
V4TBx8R2 ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
5b214bcf-62df-45ad-aa06-72c8cbb83fbb ONLINE 0 0 0
f311f8a2-9f8b-49d5-90f6-914e6e0b7e80 ONLINE 0 0 0
1e8f784f-dd1e-43bb-a2ea-8f58b84c9d1b ONLINE 0 0 0
352d3584-4fe1-46d1-9bc7-d8493487d4de ONLINE 0 0 0
ee81e127-522e-46e9-92d7-61c976425d03 ONLINE 0 0 0
c73e6a74-331f-4696-92d1-74516527f491 ONLINE 0 0 0
809f6e34-1514-43d8-afb5-81bb2062c60e ONLINE 0 0 0
e71ef200-10d7-4786-b0d3-e51887469545 ONLINE 0 0 0
errors: 1 data errors, use '-v' for a list
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:17 with 0 errors on Sun Aug 6 03:45:18 2023
boot-pool ONLINE 0 0 0
sdi3 ONLINE 0 0 0
errors: No known data errors
I would highlight this as the answer to the pool's degraded state.
zpool status -v
to find out which file is impacted and think about how to handle that.
10Gauge
You have almost helped me to a solution, but how do I resolve it ?
The file seems innocuous and deletable, but I am stumped as to how to clear the error on the Truenas Dashboard.
Do I simply rm the offending file ?
You can try that, but it's part of the system dataset, so you may need to move that to another pool (boot pool if that's all you have) and then back again.
