I am trying to address a 180 second boot stall that I believe is caused by a SCSI command timeout regarding the SAS drive cage. It does not cause any functional problem but makes reboots much slower. I do not think I can solve the actual SCSI timeout, but the mrsas driver which is being used appears to have a timeout that I am supposed to be able to adjust that is 180 seconds. The mrsas man-page says:
I set this tunable using the FreeNAS webgui with a type of "Loader":
I verified that it did put it into /boot/loader.conf.local:
I rebooted and it did not change the stall during boot and furthermore when I executed "sysctl dev.mrsas" on the command line it shows it did not change the value:
I tried rebooting again and no change. I tried changing the type to "sysctl" and rebooted; the "sysctl dev.mrsas" command then did show to new value (30000) but it did not affect the boot stall. And the manpage clearly claims it should be put into loader.conf.
The problematic logs during boot look like this:
Although it is possible the "still waiting after xx seconds for xpt_config" message are caused by something else (I do NOT have a 1394 controller) the fact that the SCSI timeout is 180 seconds by default and the "Target RESET" message happens right after the last xpt_config messages makes it seem likely that it is this SCSI timeout.
Has anyone using mrsas driver had any luck in changing this value at boot time?
-Thanks
To change the I/O timeout value for a specific mrsas driver instance, set
the following tunable value in loader.conf(5):
dev.mrsas.X.mrsas_io_timeout=NNNNNN
where NNNNNN is the timeout value in milli-seconds.I set this tunable using the FreeNAS webgui with a type of "Loader":
dev.mrsas.0.mrsas_io_timeout="30000"
dev.mrsas.0.mrsas_io_timeout="30000" # H730 scsi timeout to 30 sec (msec raw value) as it always times out on boot, default is 180000 kernel="kernel" module_path="/boot/kernel;/boot/modules;/usr/local/modules" kern.cam.ctl.ha_id=0
freenas% sysctl dev.mrsas dev.mrsas.0.SGE holes: 0 dev.mrsas.0.prp_count: 0 dev.mrsas.0.stream detection: 1 dev.mrsas.0.block_sync_cache: 0 dev.mrsas.0.reset_in_progress: 0 dev.mrsas.0.mrsas_fw_fault_check_delay: 1 dev.mrsas.0.mrsas_io_timeout: 180000 dev.mrsas.0.mrsas_debug: 31 dev.mrsas.0.io_cmds_highwater: 265 dev.mrsas.0.fw_outstanding: 0 dev.mrsas.0.reset_count: 1 dev.mrsas.0.driver_version: 07.709.04.00-fbsd dev.mrsas.0.disable_ocr: 0 dev.mrsas.0.%domain: 0 dev.mrsas.0.%parent: pci3 dev.mrsas.0.%pnpinfo: vendor=0x1000 device=0x005d subvendor=0x1028 subdevice=0x1f49 class=0x010400 dev.mrsas.0.%location: slot=0 function=0 dbsf=pci0:2:0:0 dev.mrsas.0.%driver: mrsas dev.mrsas.0.%desc: AVAGO Invader SAS Controller dev.mrsas.%parent:
freenas uhub4: <no manufacturer Gadget USB HUB, class 9/0, rev 2.00/0.00, addr 5> on usbus0 freenas uhub4: 6 ports with 6 removable, self powered freenas run_interrupt_driven_hooks: still waiting after 60 seconds for xpt_config freenas random: unblocking device. freenas run_interrupt_driven_hooks: still waiting after 120 seconds for xpt_config freenas mrsas0: Initiating Target RESET because of SCSI IO timeout! freenas run_interrupt_driven_hooks: still waiting after 180 seconds for xpt_config freenas mrsas0: Task management NOT SUPPORTED for CAM target:0 freenas mrsas0: target reset FAIL!! freenas mrsas0: Initiaiting OCR because of TM FAILURE! freenas mrsas0: [ 0]waiting for 10 commands to complete freenas mrsas0: Reset Exit with 0. freenas ses0 at mrsas0 bus 1 scbus1 target 32 lun 0 freenas ses0: <DP BP13G+EXP 3.35> Fixed Enclosure Services SPC-4 SCSI device freenas ses0: 150.000MB/s transfers freenas ses0: SES Device freenas da9 at umass-sim0 bus 0 scbus3 target 0 lun 0
-Thanks
