Trying to replace failed disk "UNIQUE constraint failed: storage_encrypteddisk.encrypted_provider"
bsodmike
Hi all,
I'm running FreeNAS-11.3-RELEASE on my primary node and was planning to upgrade it later this week.
However, I ran into a drive failing, and this is fairly normal. This server has been replacing drives fine for over a year now.
So today, I follow the usual steps. Inserted a new disk.
Visited the Pool UI, and clicked on "Replace" disk. But for the very first time I'm running into this error:
No further details in the system logs.
My pool is a RAIDZ2 and 1-disk has already failed. I guess the next step is to reboot and try replacing the failed disk again, but I didn't want to reboot it till I checked here for advice first. Also, rebooting, I don't want to run into "other" issues, till this is addressed. I'm 1-drive failure away from looking my data :o
Please note, `b7437013-0187-11ea-9ba8-b4969130e724.eli` is the actual drive that failed. The repeated entries under replacing are that of the replacement drive and the failure I get here. I have to go back and "Offline" each of those if I want to try replacing `b7437013-0187-11ea-9ba8-b4969130e724.eli` again.
root@freenas-primary:~ # zpool status -v
  pool: big-primary
 state: DEGRADED
status: One or more devices is currently being resilvered.  The pool will
    continue to function, possibly in a degraded state.
action: Wait for the resilver to complete.
  scan: resilver in progress since Wed Oct 14 19:29:59 2020
    2.93T scanned at 545M/s, 863G issued at 1.30G/s, 37.1T total
    365M resilvered, 2.27% done, 0 days 07:55:52 to go
    NAME                                                STATE     READ WRITE CKSUM
    big-primary                                         DEGRADED     0     0     0
      raidz2-0                                          DEGRADED     0     0     0
        gptid/c25bf5f0-0309-11eb-ae8e-b4969130e724.eli  ONLINE       0     0     0
        gptid/b4cde05e-0187-11ea-9ba8-b4969130e724.eli  ONLINE       0     0     0
        gptid/b54a0478-0187-11ea-9ba8-b4969130e724.eli  ONLINE       0     0     0
        gptid/b5bf4293-0187-11ea-9ba8-b4969130e724.eli  ONLINE       0     0     0
        gptid/b63637ad-0187-11ea-9ba8-b4969130e724.eli  ONLINE       0     0     0
        gptid/b6bde417-0187-11ea-9ba8-b4969130e724.eli  ONLINE       0     0     0
        replacing-6                                     UNAVAIL      0     0     0
          12415116992178932106                          UNAVAIL    264   421     0  was /dev/gptid/b7437013-0187-11ea-9ba8-b4969130e724.eli
          17088220239846819691                          OFFLINE      0     0     0  was /dev/gptid/ad373df9-0e23-11eb-ae8e-b4969130e724.eli
          2974305596880713330                           OFFLINE      0     0     0  was /dev/gptid/71d5c022-0e24-11eb-ae8e-b4969130e724.eli
          18340350378657856049                          OFFLINE      0     0     0  was /dev/gptid/832a747f-0e25-11eb-ae8e-b4969130e724.eli
        gptid/b8b2f2b1-0187-11ea-9ba8-b4969130e724.eli  ONLINE       0     0     0
errors: No known data errors
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0 in 0 days 00:05:19 with 0 errors on Mon Oct 12 03:50:19 2020
    freenas-boot  ONLINE       0     0     0
      mirror-0  ONLINE       0     0     0
        da8p2   ONLINE       0     0     0
        da9p2   ONLINE       0     0     0
Appreciate any and all help,
Thanks!!
bsodmike
I backed up the config and rebooted the host. Tried replacing the failed disc and it worked this time, no error!
Will wait till the resilver is done and backup the config then once more.
