TrueNAS12.0-U6.1 Pool offline
misterpele
I have a TrueNAS server I use at home and was working fine until last night. I got an error my Pool went offline.
I have 32 GIG RAM. 8 Hard drives ZFS Pool.
MY CPU is a Ryzen 7 2700X
When I look at pools it says offline and gives me a chance to export/disconnect.
Zpool status just gives me boot-ool and da0p2 both online
When I do a smartctl -a on them there seems to be no errors.
I will provide anything else that is needed.
My big question is, is everything in that pool lost?
NugentS
What hardware are you using - all of it. Also Scale or Core. How are the disks connected to the motherboard, onboard SATA, USB, HBA what. Basically complete details please.
Output of zpool status -v in code tags
Output of glabel status (if core) in code tags
smartctl --scan in code tags
Do you have backups?
misterpele
I am using Core. The Disks are connected to the Motherboard SATA.
Here is the zpool and the glabel.
for smartctl do you want the smartctl /a /dev/ada1, etc ? If so I will do that next, if it needs to be different please advise.
Backups were supposed to be on but none are there.
NugentS
In code tags please - use Putty to log into the server and copy and paste from there
smartctl --scan is what I asked for please, in code tags
I will also repeat "What hardware are you using - all of it."
misterpele
The hardware I am using is
8 12TB SATA harddives 5 Toshiba, 3 Seagate connected to motherboard
1 256 NVMe for Boot drive
2700 AMD Ryzen
TUF Motherboard x570-plus
600w cool master power supply
some cheap graphics card
TrueNAS CORE 12.0-u6.1
32 GB RAM
misterpele
I am in via putty. I didn't have the admin login clicked.
Not sure what you want typed after smartctl with what I have shown.
misterpele
Not sure this makes a difference, but I still see The name and path I gave it in Sharing-WindowShares.
NugentS
"smartctl --scan" is what I am looking for
And with putty you can copy and paste a lot easier and then insert into code tags in this forum so its easy to read - no photos please
Whilst in putty type "ls /mnt". Can you see the pool name there or not. If you can cd further into the folder structure and check if your data is there or not.
Your boot drive is da0
Your other drives seem to be listed as ada implying that they are on something different to the da0 of the boot pool - that they are connected differently. Also the motherboard has 8 SATA Ports to which you appear to have attached 9 disks plus an nvme drive
Also you have nvd0 which you haven't mentioned in your spec - whats that used for? Is that the boot disk?
You also don't mention how you disks are organised. 12 * Individual pools? RAIDZ1, Z2, Mirrors, stripes
Look at the spec in my signature and produce something similar
misterpele
Running smartctl --scan
 root@truenas[~]# smartl --scan
zsh: command not found: smartl
root@truenas[~]# smartctl --scan
/dev/ada0 -d atacam # /dev/ada0, ATA device
/dev/ada1 -d atacam # /dev/ada1, ATA device
/dev/ada2 -d atacam # /dev/ada2, ATA device
/dev/ada3 -d atacam # /dev/ada3, ATA device
/dev/ada4 -d atacam # /dev/ada4, ATA device
/dev/ada5 -d atacam # /dev/ada5, ATA device
/dev/ada6 -d atacam # /dev/ada6, ATA device
/dev/ada7 -d atacam # /dev/ada7, ATA device
/dev/nvme0 -d nvme # /dev/nvme0, NVMe device
When running ls /mnt
root@truenas[~]# ls /mnt
md_size
root@truenas[~]#
I was using RaidZ2 for my pool.
I boot from NVME
NugentS
Well you could try answering the previous questions
NugentS
Oh and what happens if you type "zpool import" at the command line?
misterpele
root@truenas[~]# zpool import
   pool: boot-pool
  state: ONLINE
 action: The pool can be imported using its name or numeric identifier.
        boot-pool   ONLINE
          nvd0p2    ONLINE
   pool: MainNAS
  state: ONLINE
        MainNAS                                         ONLINE
          raidz2-0                                      ONLINE
            gptid/156864e2-832a-11ec-8e9c-a85e4550970d  ONLINE
            gptid/15d02660-832a-11ec-8e9c-a85e4550970d  ONLINE
            gptid/15bb2646-832a-11ec-8e9c-a85e4550970d  ONLINE
            gptid/15e4ae7c-832a-11ec-8e9c-a85e4550970d  ONLINE
            gptid/15f8f663-832a-11ec-8e9c-a85e4550970d  ONLINE
            gptid/16430264-832a-11ec-8e9c-a85e4550970d  ONLINE
            gptid/162834a9-832a-11ec-8e9c-a85e4550970d  ONLINE
            gptid/16837624-832a-11ec-8e9c-a85e4550970d  ONLINE
root@truenas[~]#
NugentS
Looks to me like you can type zpool import MainNAS which should just import the pool
@HoneyBadger - you just got in front of me
misterpele
I ran that and it seemed to run well. I hit esc by accident so can't copy and paste what it said. but in the GUI in snapshots it now shows MainNAS.
Sorry to be such a nag. What would be the next step with this?
FYI i tried to re-run the zpool import MainNAS and it says pool exists with that name (so I think that is good)
zpool import gave me this:
   pool: boot-pool
  state: ONLINE
        boot-pool   ONLINE
          nvd0p2    ONLINE
root@truenas[~]#
NugentS
If its imported the pool, then you are finished.
Does the pool exist?
