TrueNAS > Storage > Disk shows nothing
Yunion
Hardware:
Motherboard: MSI 970ag43_plus
CPU: AMD FX 6100
RAM: 20GB
SSD 1: 256GB
HDD 1: WD1TB
HDD 2: WD1TB
HDD 3: TOSHIBA 1TB
I had TrueNAS already install inside proxmox PE running without major problems, the thing is I had to reinstall Proxmox and restore all the virtual machines. Everything goes well except for TrueNAS Core who doesn't show me the three hdd I had on Storage < Disks. I already create a new VM and install TrueNAS Core 13 from scratch in order to discard the possibility of being a problem of the host (Proxmox PE) which apparently it's not. TrueNAS did shown the hdd on geom disk list command but shows nothing on Storage < Disks
root@truenas[~]# geom disk list
Geom name: da0
Providers:
1. Name: da0
Mediasize: 68719476736 (64G)
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r2w2e4
descr: QEMU QEMU HARDDISK
ident: (null)
rotationrate: 0
fwsectors: 63
fwheads: 255
Geom name: da1
Providers:
1. Name: da1
Mediasize: 1000204886016 (932G)
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r0w0e0
ident: (null)
rotationrate: unknown
fwsectors: 63
fwheads: 255
Geom name: da2
Providers:
1. Name: da2
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r0w0e0
ident: (null)
fwsectors: 63
fwheads: 255
Geom name: da3
Providers:
1. Name: da3
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r0w0e0
ident: (null)
fwsectors: 63
fwheads: 255
Geom name: cd0
Providers:
1. Name: cd0
Mediasize: 1037957120 (990M)
Sectorsize: 2048
Mode: r0w0e0
descr: QEMU QEMU DVD-ROM
ident: (null)
fwsectors: 0
fwheads: 0
I'm losing my mind trying to fix this, I've alredy search about this subjet but haven't get a clear answer. Any suggestion I would really appreciate it
mav@
TrueNAS does not like multiple disks with matching identification or as in this case disks without identification. Make your Proxmox assign some serial numbers to the disks. Or better pass them directly somehow without virtualization to keep their original appearance and behavior.
PS: New versions should improve the situation by giving warning about matching identification, but allow override. Though still should be avoided.
southman
I have a similar problem with my drives that are connected to usb3.0 dock ( icybox ). I checked the serial numbers in shell and all the drives appear with different serial numbers.
The difference is that only one of my drives appear but not none.
If someone have a solution.
Thanks
