TrueNas stecked in boot loop
tJonathan
Hello, I have a small TrueNas server virtualized on proxmox. TrueNas has at some point gefreezd, so I stopped the VM. But now TrueNas is stuck in a boot loop.
I think there is a problem with the pool, because when I unmount the HDDs TrueNas boots without any problems. I can also press Control C and the system boots, but in the Task tab I see that it tries to import the pool but gets stuck at 80. I also can't access the data, even though I see the pool listed decrypted in storage.
I also tried to roll in a backup, but it doesn't help either. Online I have also found nothing to the problem.
According to Proxmox, the VM always does nothing for a while, and then writes something to the hard drive.
Maybe someone can help me here, I would be very grateful!
Translated with www.DeepL.com/Translator (free version)
tJonathan
Here are some of the outputs i get from the Console.
jgreco
Resident Grinch
Welcome to the forums.
Sorry to hear you're having trouble. Please take a few moments to review the Forum Rules, conveniently linked at the top of every page in red, and pay particular attention to the section on how to formulate a useful problem report, especially including a detailed description of your virtual hardware, your hypervisor's physical hardware, HBA, and specific hard drives being used.
I also suggest reviewing the virtualization guides, and ask that you outline any deviations between your setup and known good setups.
tJonathan
Thanks for the tip. So the CPU is an 8 core kvm64 processor. As I said the whole thing is running on a proxmox system, with an Intel i5-11400 on a Z590 motherboard. The VM has 16GB RAM. I have three HDDs, all WD-RED Plus with 4TB in a RaidZ1 config, directly forwarded to the VM via sata.
The whole thing also ran two years absolutely stable until recently.
tJonathan
root@pTrueNAS[~]# zpool status
  pool: boot-pool
 state: ONLINE
  scan: scrub repaired 0B in 00:00:21 with 0 errors on Tue Nov 15 03:45:21 2022
          ada0p2    ONLINE       0     0     0
errors: No known data errors
  pool: data
 state: ONLINE
  scan: scrub repaired 0B in 13:47:59 with 0 errors on Tue Nov 29 13:47:59 2022
          raidz1-0                                      ONLINE       0     0 0
            gptid/29df45a3-0a98-11ed-999e-6d489391aa3c  ONLINE       0     0 0
            gptid/29eae0de-0a98-11ed-999e-6d489391aa3c  ONLINE       0     0 0
            gptid/29fbc57f-0a98-11ed-999e-6d489391aa3c  ONLINE       0     0 0
This output i get form running zpool status. Maybe it helps ....
tJonathan
So good news is that I can at least access the pool via the shell and read and write data.
jgreco
Resident Grinch
That's probably not acceptable and it's certainly dangerous and ill-advised. I would imagine that this is being handled as some sort of virtual disk abstraction, which is basically going to have problems similar to RDM under ESXi. Pass through the entire PCIe controller using PCIe passthru as outlined in the virtualization guide I previously provided. Any opportunity that exists for I/O restructuring or reordering by the hypervisor platform presents significant risks for ZFS.
