Hi everyone!
I've truenas scale installed with two interface (192.168.0.49 and 192.168.0.75). I use the 75 to connect to apps (Plex, radarr, sonarr, etc.) and works fine.
Then, I installed pi-hole and DNS Records (.local) works fine. For example, asus.local and it connect to 192.168.0.1.
But, if I want to connect to app's truenas is not possible with pi-hole, because is not possible put the ports. Then, after to read a lot of information, I installed nginx app in Truenas and I have configurated to static ip (192.168.0.69) and add DNS Record in pi-hole , for example (radarr.local to 192.168.0.69) and add proxy hosts in nginx (radarr.local to 192.168.0.75:30025) but doesn't works, although nginx works because if I connect to 192.168.0.69:80 I can see the congratulations page's.
Any idea to fix it?
THANKS!
Any idea to fix it?
THANKS!
