TrueNAS Scale Nextcloud cron not working
frankyvee
Thanks for all the input. I installed NextCloud and then inputted the data above for the cronjob, but can only achieve the schedule of Every 5 Minutes. So unless there is more specific input, I'll have to keep messing with it. I did try and test it out to enable cron schedule after installing the app, and got the following error message.
I'll keep trying out different schedules. I've also noticed that if I do try and "edit" the installation of NextCloud, then the app seems to be stuck in deploying 1/2. Any thoughts there from anyone? What i've done in the past is delete that NextCloud instance and re download. But I'm hoping doing that over and over doesn't ruin anything in the short term.
I just noticed your second question. I experienced that as well. What I did to install a clean installation to make sure there were no remnants of the previous installation files of Next Cloud was to delete the dataset that NextCloud was on. Then recreate the dataset in Truenas for it and start the installation from the beginning. Hope this helps.
TYFLOOZY
I have looked at Nexcloud setttings, CRON is selected.
I did figure out the deploying issue, I had accidently messed up on the dataset (I had one Home Assistant drive mapped to nexcloud and i forget whatever else) and so I deleted and created a new data set.
So I still need to figure out the cronjob schedule issue and now ran into an issue where i tried updating Nextcloud on Truenas and now NC is stuck in Maintenance Mode. If there are any recommended threads on that, it would be appreciated.
TYFLOOZY
Never mind on the maintenance mode, got it figured out.
TYFLOOZY
So I started fresh, deleted nexcloud and the dataset, as well as updated Nextcloud and TrueNAS and the overall install seemed a bit better since I was trying to connect Collabora. I still can't get CRON to work though, i've used all sorts of commands and tried a few schedules but stuck to the */5**** pretty consistently.
Do I need to go into the NextCloud shell to figure out the specific cron command for my system? Everyone seems to be able to get it to work with different commands. And if there is a way to figure out what my special command would be, how do I find that? I've been on youtube, this forum, Lawrence tech forum and Nextcloud forums and can't seem to get it, this is my first time trying to set up a cron.
demuxer86
I have the same issue. Truenas scale fully up to date. Nextcloud official app fresh install (twice)... no matter what I do, I cannot get cron jobs to work. I tried the scripts in this thread too... just nothing works :/
demuxer86
Nevermind, i got it! I had to change the container name in the script, but I thought i needed the k8s at the beginning.
I used (in truenas shell)
docker ps | grep nextcloud
found my container name, which was nextcloud_testcloud and so the cron script is
docker exec --user www-data `docker ps | grep "nextcloud_testnextcloud" | awk '{ print $1; }'` php /var/www/html/cron.php
This works now!!
demuxer86
Oops, wrong script. Can't edit messages???
Anyway, the script i used was
docker exec --user www-data `docker ps | grep "nextcloud_testcloud" | awk '{ print $1; }'` php /var/www/html/cron.php
TYFLOOZY
So it seems like this section here - "nextcloud_testcloud" - is specific to your truenas instance, right?. How did you figure out what phrase to use in the parenthesis? Is this the name that is used on the application or the name that is used for the dataset or something else?
Also this can still be done in the GUI as well, right? The shell is great, I'm just not as familiar or just confident in using the shell and end up breaking things.
Isma
good, I tried all the possible combinations in my case, but my nextcloud data is in another set of disks, this being the address
Nextcloud Storage
Nextcloud Data Volume
/mnt/Raidz2/nextclouddata/
Postgres Data Volume
/mnt/SSD/nextclouddata/1
try
docker exec --user www-data `docker ps | grep "nextcloud_nextcloud" | awk '{ print $1; }'` php /var/www/html/cron.php
docker exec --user www-data `docker ps | grep "k8s_nextcloud_nextcloud" | awk '{ print $1; }'` php /var/www/html/cron.php
And changing all the urls that point to cron.php
******| awk '{ print $1; }'` php /mnt/Raidz2/nextclouddata/html/cron.php
******| awk '{ print $1; }'` php /Raidz2/nextclouddata/html/cron.php
******| awk '{ print $1; }'` php /nextclouddata/html/cron.php
******| awk '{ print $1; }'` php /html/cron.php
******| awk '{ print $1; }'` php /cron.php
etc
At the moment I configure webcron and I use the recommended app from https://www.easycron.com/ pointing directly to url/cron.php and it works for me
any ideas to configure cron?
Isma
Nextcloud Storage
try
etc
the problem in my case was the user of the command
with me it works like this
docker exec --user root `docker ps | grep "nextcloud_nextcloud" | awk '{ print $1; }'` php cron.php
o_minchev
After trying to run in shell, I received:
root@truenas-scale:~$ docker ps
-bash: docker: command not found
Help, please.
aherbjornsen
Docker was removed in Cobia. See this thread for solution:
Dave41
Cron entry in the Nexcloud setup beat me up pretty badly, Kept getting this message:
middlewared.service_exception.CallError: [EFAULT] Failed to update App: Error: UPGRADE FAILED: failed to create resource: CronJob.batch "nextcloud-cronjob" is invalid: spec.schedule: Invalid value: "*/15****": expected exactly 5 fields, found 1: [*/15****]
SOLUTION: The proper format is */15 * * * * the five entries need a SPACE between them.
