winnielinnie
- Oct 22, 2019
Is this destined to land in Core as well, or is it only for SCALE?We've updated the docs as well to explain this process in more detail.
I don't disable password. I disable password login for SSH. Everywhere in my data centre. I still need a root password to login at the console via IPMI in case of an emergency.Actually, starting with Bluefin it is. If you disable password forrootuser, like you do, you will not be able to login withrootuser into UI. In Angelfish you can. People were complaining into forums they cannot login into UI anymore withrootuser. :)
I will create the user and name it "admin" - let's see where this is going. Thanks for your hints.
I disable password login for the SSH service. Everywhere. Public key only.Historically, disabling password for root in GUI (in general password authentication) did not prevent password login.
Right, that's the sensible way of doing SSH.I disable password login for the SSH service. Everywhere. Public key only.
This is a pretty large feature which still has a lot more improvements slated as others have hinted at (Being able to delegate specific admin permissions). Unlikely for a backport due to the amount of churn.Is this destined to land in Core as well, or is it only for SCALE?
Stay tuned ;)As long as logging in as "admin" vs. as "root" leads to the exact same UI that is itself running with the exact same privileges, there really is no difference. As soon as we get role based granular administration, we are talking. Maybe this change is just a first step. Also: audit of administrative changes.
Not clear if this is a bug or working as designed...
I've added my normal user "foo" to the builtin_administrators group and can login to the web GUI. The alert has gone away, however I can still log in as root. The language made it sound like once you have another admin, logging in as root would be disabled. Do I need to explicitly disable root's password?
The other thing that was a bit odd was that the 2FA token that I used as root still works as "foo". I don't see any way to configure it per user, so I'm assuming that's correct?
Yes.Do I need to explicitly disable root's password?
A rewrite of the warning is definitely in order then. At the moment it's harmful since it strongly implies (or directly states) that access for root will be rescinded when another administrator is created.Yes.
Select builtin_administrators and root groups on the Auxiliary Group dropdown list.Just upgraded to TrueNAS-SCALE-22.12.0
Saw a warning message:
Root user has their password disabled, but as there are no other users granted with a privilege of Local Administrator, they can still log in to the Web UI. Please create a separate user for the administrative purposes in order to forbid root from logging in to the Web UI.
Question: how to create a user granted with a privilege of Local Administrator?
builtin_administrators as auxiliary group should be sufficient. The numbers are DB IDs and shouldn't have been exposed (bug being fixed in 22.12.1 - will be group names).Select builtin_administrators and root groups on the Auxiliary Group dropdown list.
Auxiliary Groups should look like 41,90,91
It will add builtin_users once saved
root@tndev[~]# passwd joeadmin New password: Abc123! Retype new password: Abc123! passwd: password updated successfully root@tndev[~]# id joeadmin uid=500(joeadmin), gid=50(staff),groups=50(staff),544(builtin_administrators),545(builtin_users),1001(family),1003(homesvcs),1000(mediasvcs),20(sudo),6667(timemachine) root@tndev[~]# service middlewared stop root@tndev[~]# service middlewared start
help please!
Managed to get "everything" working in this regard with my named user able to login to the UI and root disabled. Then I rebooted...
Now my named user can't login via the UI and neither can root.
I've attempted resetting the user's password from the system console to make sure I actually remembered it correctly. Did not help.
Code:root@tndev[~]# passwd joeadmin New password: Abc123! Retype new password: Abc123! passwd: password updated successfully root@tndev[~]# id joeadmin uid=500(joeadmin), gid=50(staff),groups=50(staff),544(builtin_administrators),545(builtin_users),1001(family),1003(homesvcs),1000(mediasvcs),20(sudo),6667(timemachine) root@tndev[~]# service middlewared stop root@tndev[~]# service middlewared start
Now I'm locked out of the webUI completely. neither joeadmin nor root can authenticate successfully, though ssh works fine.
Is there a way to re-enable the root access to the UI or otherwise re-validate/config my named user from the console CLI to fix whatever isn't set correctly after reboot?
