This might sound like a silly question, but is it possible to deploy truenas scale into an already deployed k3s cluster as a worker node or does it have to be a standalone cluster/node?
It's not a standard deployment model... so I think it would require someone with developer skills to review and do 1st deployment and identify specific changes or setup requirements needed.
The other approach is to create a VM and install the K3s worker node in the VM. that is probably the safest and most reliable approach.
You can then use the Apps catalog for specific applications.
