- Mar 6, 2014
Right now we don't have support for clustered services. I'm using a Supermicro A2SDi-8C-HLN4F. For my testing / dev purposes this is sufficient. This is personal use, not something that has been through our official QE / hardware processes. It works well and I'm happy with it, but it may not be a perfect fit for everyone out there (limited number of sata ports, too many gigabit NICs, etc). I'm sure there are much more opinionated people that can give recommendations.thx for that quick answer
which SBC is that?
they are running as a cluster or single node?
If you want something certified to work with FN / TN, then you can look at the official products iXsystems sells (FreeNAS mini and FreeNAS certified).
