goddard
- Jul 26, 2022
I just did my first update on TrueNAS and after the update my pool is not showing in the interface although in the shell "zpool import" shows the pool is online.
root@truenas[~]# zpool import
pool: main
state: ONLINE
status: Some supported features are not enabled on the pool.
(Note that they may be intentionally disabled if the
'compatibility' property is set.)
action: The pool can be imported using its name or numeric identifier, though
some features will not be available without an explicit 'zpool upgrade'.
main ONLINE
raidz2-0 ONLINE
1234-11ec-829f-3ceceffa67d2 ONLINE
1234-fa52-11ec-829f-3ceceffa67d2 ONLINE
pool: main
state: ONLINE
main ONLINE
raidz2-0 ONLINE
