Hello everyone,
I would like to use some swarm intelligence for my problem because I keep getting the same result. I've already searched google and
the forum but couldn't find the right solution. If there is already a suitable thread and I couldn't find it due to my search skills,
I would be very happy about a link to the correct thread.
So that I don't continue to beat around the bush, now to my actual problem (2.1 Problem explanation:).
In the following I will first try to describe my structure as precisely as possible.
My physical network top to bottom starting from the gateway:
Similarly, now expanded with the virtual components, vlans and ip addresses.
1. Requirement/Problem:
The TrueNAS Scale interface in the CIFS/SMB network, which provides CIFS/SMB shares, must be made accessible by the Windows client.
1.1 Problem explanation:
In the current configuration, the TrueNAS Scale has already set the default gateway [*.*.20.254] on the storage management interface
in order to reach the web interface. That's why there is currently "asyncrone routing" when connecting the TrueNAS Scale CIFS/SMB shares.
In order to correct the routing, a gateway must also be set for the TrueNAS Scale interface in the CIFS/SMB network.
This can be done using the following commands in the Linux Shell of the TrueNAS Scale.
Show current routing table:
Set another route:
Check routing table:
2. Requirement/Problem:
The TrueNAS Scale interface on the NFS network that provides NFS shares must be exposed by the various hypervisors (XCP-ng02 & nested XCP-ng03).
The NFS share can be reached and accessed by the XCP-ng02, but not by the XCP-ng03, which runs nested on the TrueNAS scale.
When I run a TCPdump on the TrueNAS Scale, I see incoming packets tagged in VLAN 150 on both the interface "br0" and interface "bond0",
which are sent by the XCP-ng03. However, the packets are not passed on to the “vlan150” interface because they cannot be seen there using TCPdump.
2.2 Solution:
Unfortunately I don't have it because I'm kind of stuck. Do any of you have an idea or analysis approach to find a solution for this too?
The only approach I would have would be to set the parent interface to "br0.150" for the interface "vlan150",
but unfortunately this is not possible via the GUI or CLI, there I only have the preselection "bond0" or one of those Physical adapter.
| UDM Pro | ||
| <---{10G-DAC}---> | USW Enterprise | |
| <---{1G-Copper}---> | Windows-Client | |
| <---{1G-Copper}---> | XCP-ng | |
| <---{2x-1G-Copper}---> | TrueNAS Scale |
| UDM Pro [[*.*.20.254],[*.*.30.254],[*.*.100.254], | [*.*.150.254],[*.*.160.254]] | ||||
| <---{TAGGED VLANs 20,30,100,150,160}---> | USW Enterprise | ||||
| <---{UNTAGGED VLAN 100}---> | Windows-Client | [*.*.100.100] | |||
| <---{TAGGED VLANs 30,150}---> | XCP-ng02 | [[*.*.30.2],[*.*.150.2]] | |||
| <---{TAGGED VLANs 20,30,150,160}---> | TrueNAS Scale | ||||
| >>> enp38s0: | |||||
| >>> enp38s0: | |||||
| >>> bond0: | |||||
| >>> br0: | {bond0,vlan20,vlan150} | ||||
| <---> nested XCP-ng03 | [[*.*.30.3],[*.*.150.3]] | ||||
| >>> vlan20: | {bond0} [*.*.20.10] | ||||
| >>> vlan150: | {bond0} [*.*.150.10] | ||||
| >>> vlan160: | {bond0} [*.*.160.10] |
|| VLAN 20 = Storage Management = 172.31.20.0/24
|| VLAN 30 = Hypervisor Management = 172.31.30.0/24
|| VLAN 100 = Clients = 172.31.100.0/24
|| VLAN 150 = NFS = 172.31.150.0/24
|| VLAN 160 = CIFS/SMB = 172.31.160.0/24
1.2 Solution:Client connection request:
[*.*.100.100] --> [*.*.100.254] --> [*.*.160.10]
TruneNAS Scale response:
[*.*.20.10] --> [*.*.20.254] --> [*.*.100.100]
root@truenasscale[~]# route -nSet another route:
root@truenasscale[~]# route add default gw {Gateway-IP} {Interface}Check routing table:
root@truenasscale[~]# route -n2. Requirement/Problem:
2.2 Solution:
