TrueNAS-SCALE-22.12.0 from TrueNAS-13.0-U3.1 upgrade all datasets missing
wan2bretired
TrueNAS-13.0-U3.1 to TrueNAS-SCALE-22.12.0 upgraded via iso/usb install/upgrade. Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz, 8Gb ram, boot drive is ssd with a old Jailpool ssd and raidz3 10 drive pool, zpoolbak. This is a backup server to my main nas ( currently core 13.0-U3.1 ) and I was testing the upgrade on this first. This is the second attempt at the upgrade, this first was through the GUI, but the same results.
The pools jailpool and zpoolbak show up, but the datasets are all missing ( displays No Datasets ), however in the cli they are all present, and if I try to set up a replication task they show up in the drop down, and furthermore all smb shares show up on my PC in windows explore.
Any sugestions?
Patrick M. Hausen
Have you tried once to export via CLI, import via UI?
wan2bretired
I tried zpool export from the CLI and import from GUI with no datasets appearing. I also did a clean install from the usb iso, imported both pools via GUI, and restored my config., but still no Datasets. SMB shares are still showing on PC, and datasets will display in drop down in replication tasks. Now I am afraid to do this on my main server ( though newer and completely dif. hardware).
Patrick M. Hausen
zfs show mountpoint
zfs show canmount
wan2bretired
I get unrecognized command show for both.
using zfs list zpoolbak/PhotoLibrary (see below). PhotoLibrary is a dataset. If I enter zfs list zpoolbak/PhotoLibrary/Porttfolio, I receive that "dataset does not exit".
Patrick M. Hausen
Patrick M. Hausen
Please use SSH and copy & paste as text inside CODE tags. I cannot read that.
Patrick M. Hausen
Please just use the commands I stated as I did. zfs get mountpoint somepool will tell us the mount point of that particular pool's top level dataset. But that is in no way part of your problem. The datasets below the top level one are. zfs get mountpoint without anything added will tell us the mount points of all your datasets, specifically the ones below the top level - which is what I need to help you with your problem.
And then copy and paste the text in code tags like so, please:
root@freenas[~]# zfs get mountpoint
NAME                                                   PROPERTY    VALUE                                       SOURCE
boot-pool                                              mountpoint  none                                        local
boot-pool/ROOT                                         mountpoint  none                                        inherited from boot-pool
boot-pool/ROOT/13.0-RELEASE                            mountpoint  /                                           local
boot-pool/ROOT/13.0-U1                                 mountpoint  /                                           local
boot-pool/ROOT/13.0-U1.1                               mountpoint  /                                           local
boot-pool/ROOT/13.0-U2                                 mountpoint  /                                           local
boot-pool/ROOT/13.0-U3                                 mountpoint  /                                           local
boot-pool/ROOT/13.0-U3.1                               mountpoint  /                                           local
boot-pool/ROOT/13.0-U3.1@2022-07-08-23:54:17           mountpoint  -                                           -
boot-pool/ROOT/13.0-U3.1@2022-07-25-21:04:14           mountpoint  -                                           -
boot-pool/ROOT/13.0-U3.1@2022-09-01-20:32:02           mountpoint  -                                           -
boot-pool/ROOT/13.0-U3.1@2022-11-02-20:25:44           mountpoint  -                                           -
boot-pool/ROOT/13.0-U3.1@2022-11-16-20:58:01           mountpoint  -                                           -
hdd                                                    mountpoint  /mnt/hdd                                    default
hdd/backup                                             mountpoint  /mnt/hdd/backup                             default
hdd/backup/jails                                       mountpoint  /mnt/hdd/backup/jails                       default
In remote support I try to get a mental image of your system to diagnose the problem. You are - because I have no access to the system in question - my hands and my eyes. Please do not try to be smart. Just type exactly as I say and tell me the results. Thank you.
wan2bretired
Thanks for your assistance. I had to figure out how to do what you did to post regarding pasting text in the box.
root@truenas[~]# zfs get canmount
boot-pool        canmount  off       local
boot-pool/.system        canmount  on        default
boot-pool/.system/configs-3b1c2a4fb0c04f65ad6887d0d3b2bca7                                                 canmount  on        default
boot-pool/.system/cores        canmount  on        default
boot-pool/.system/ctdb_shared_vol        canmount  on        default
boot-pool/.system/glusterd        canmount  on        default
boot-pool/.system/rrd-3b1c2a4fb0c04f65ad6887d0d3b2bca7                                                     canmount  on        default
boot-pool/.system/samba4        canmount  on        default
boot-pool/.system/samba4@wbc-1677013318        canmount  -         -
boot-pool/.system/services        canmount  on        default
boot-pool/.system/syslog-3b1c2a4fb0c04f65ad6887d0d3b2bca7                                                  canmount  on        default
boot-pool/.system/webui        canmount  on        default
boot-pool/ROOT        canmount  off       local
boot-pool/ROOT/22.12.0        canmount  on        default
boot-pool/ROOT/22.12.0@2023-02-21-20:48:43        canmount  -         -
boot-pool/ROOT/Initial-Install        canmount  noauto    local
boot-pool/grub        canmount  off       local
jailpool        canmount  on        default
jailpool@auto-2023-02-20_18-47        canmount  -         -
jailpool/.system        canmount  on        default
jailpool/.system@auto-2023-02-20_18-47        canmount  -         -
jailpool/.system/configs-3b1c2a4fb0c04f65ad6887d0d3b2bca7                                                  canmount  on        default
jailpool/.system/configs-3b1c2a4fb0c04f65ad6887d0d3b2bca7@auto-2023-02-20_18-47                            canmount  -         -
jailpool/.system/cores        canmount  on        default
jailpool/.system/cores@auto-2023-02-20_18-47                                                               canmount  -         -
jailpool/.system/ctdb_shared_vol        canmount  on        default
jailpool/.system/ctdb_shared_vol@auto-2023-02-20_18-47                                                     canmount  -         -
jailpool/.system/glusterd        canmount  on        default
jailpool/.system/glusterd@auto-2023-02-20_18-47                                                            canmount  -         -
jailpool/.system/rrd-3b1c2a4fb0c04f65ad6887d0d3b2bca7                                                      canmount  on        default
jailpool/.system/rrd-3b1c2a4fb0c04f65ad6887d0d3b2bca7@auto-2023-02-20_18-47                                canmount  -         -
jailpool/.system/samba4        canmount  on        default
jailpool/.system/samba4@auto-2023-02-20_18-47                                                              canmount  -         -
jailpool/.system/services        canmount  on        default
jailpool/.system/services@auto-2023-02-20_18-47                                                            canmount  -         -
jailpool/.system/syslog-3b1c2a4fb0c04f65ad6887d0d3b2bca7                                                   canmount  on        default
jailpool/.system/syslog-3b1c2a4fb0c04f65ad6887d0d3b2bca7@auto-2023-02-20_18-47                             canmount  -         -
jailpool/.system/webui        canmount  on        default
jailpool/.system/webui@auto-2023-02-20_18-47                                                               canmount  -         -
jailpool/Unbuntu_mani-mla6i5        canmount  -         -
jailpool/Unbuntu_mani-mla6i5@auto-2023-02-20_18-47                                                         canmount  -         -
jailpool/Unbuntu_mani-mla6i5_unbuntu_sven        canmount  -         -
jailpool/Unbuntu_mani-mla6i5_unbuntu_sven@auto-2023-02-20_18-47                                            canmount  -         -
jailpool/Unbuntu_mani-mla6i5_unbuntu_sven_vpn                                                              canmount  -         -
jailpool/Unbuntu_mani-mla6i5_unbuntu_sven_vpn@auto-2023-02-20_18-47                                        canmount  -         -
jailpool/VPNserver-gzptk        canmount  -         -
jailpool/VPNserver-gzptk@auto-2023-02-20_18-47                                                             canmount  -         -
jailpool/apps        canmount  on        default
jailpool/apps@auto-2023-02-20_18-47        canmount  -         -
jailpool/apps/Clamav-7wfo7m        canmount  -         -
jailpool/apps/Clamav-7wfo7m@auto-2023-02-20_18-47                                                          canmount  -         -
jailpool/apps/nextcloud        canmount  on        default
jailpool/apps/nextcloud@auto-2023-02-20_18-47                                                              canmount  -         -
jailpool/apps/nextcloud/config        canmount  on        default
jailpool/apps/nextcloud/config@auto-2023-02-20_18-47                                                       canmount  -         -
jailpool/apps/nextcloud/db        canmount  on        default
jailpool/apps/nextcloud/db@auto-2023-02-20_18-47                                                           canmount  -         -
jailpool/apps/nextcloud/themes        canmount  on        default
jailpool/apps/nextcloud/themes@auto-2023-02-20_18-47                                                       canmount  -         -
jailpool/iocage        canmount  on        default
jailpool/iocage@auto-2023-02-20_18-47        canmount  -         -
jailpool/iocage/download        canmount  on        default
jailpool/iocage/download@auto-2023-02-20_18-47                                                             canmount  -         -
jailpool/iocage/download/11.3-RELEASE        canmount  on        default
jailpool/iocage/download/11.3-RELEASE@auto-2023-02-20_18-47                                                canmount  -         -
jailpool/iocage/download/12.1-RELEASE        canmount  on        default
jailpool/iocage/download/12.1-RELEASE@auto-2023-02-20_18-47                                                canmount  -         -
jailpool/iocage/download/12.2-RELEASE        canmount  on        default
jailpool/iocage/download/12.2-RELEASE@auto-2023-02-20_18-47                                                canmount  -         -
jailpool/iocage/download/12.3-RELEASE        canmount  on        default
jailpool/iocage/download/12.3-RELEASE@auto-2023-02-20_18-47                                                canmount  -         -
jailpool/iocage/download/13.0-RELEASE        canmount  on        default
jailpool/iocage/download/13.0-RELEASE@auto-2023-02-20_18-47                                                canmount  -         -
jailpool/iocage/download/13.1-RELEASE        canmount  on        default
jailpool/iocage/download/13.1-RELEASE@auto-2023-02-20_18-47                                                canmount  -         -
jailpool/iocage/images        canmount  on        default
jailpool/iocage/images@auto-2023-02-20_18-47                                                               canmount  -         -
jailpool/iocage/jails        canmount  on        default
jailpool/iocage/jails@auto-2023-02-20_18-47        canmount  -         -
jailpool/iocage/log        canmount  on        default
jailpool/iocage/log@auto-2023-02-20_18-47        canmount  -         -
jailpool/iocage/releases        canmount  on        default
jailpool/iocage/releases@auto-2023-02-20_18-47                                                             canmount  -         -
jailpool/iocage/releases/11.3-RELEASE        canmount  on        default
jailpool/iocage/releases/11.3-RELEASE@auto-2023-02-20_18-47                                                canmount  -         -
jailpool/iocage/releases/11.3-RELEASE/root        canmount  on        default
jailpool/iocage/releases/11.3-RELEASE/root@auto-2023-02-20_18-47                                           canmount  -         -
jailpool/iocage/releases/12.1-RELEASE        canmount  on        default
jailpool/iocage/releases/12.1-RELEASE@auto-2023-02-20_18-47                                                canmount  -         -
jailpool/iocage/releases/12.1-RELEASE/root        canmount  on        default
jailpool/iocage/releases/12.1-RELEASE/root@auto-2023-02-20_18-47                                           canmount  -         -
jailpool/iocage/releases/12.2-RELEASE        canmount  on        default
jailpool/iocage/releases/12.2-RELEASE@auto-2023-02-20_18-47                                                canmount  -         -
jailpool/iocage/releases/12.2-RELEASE/root        canmount  on        default
jailpool/iocage/releases/12.2-RELEASE/root@auto-2023-02-20_18-47                                           canmount  -         -
jailpool/iocage/releases/12.3-RELEASE        canmount  on        default
jailpool/iocage/releases/12.3-RELEASE@auto-2023-02-20_18-47                                                canmount  -         -
jailpool/iocage/releases/12.3-RELEASE/root        canmount  on        default
jailpool/iocage/releases/12.3-RELEASE/root@auto-2023-02-20_18-47                                           canmount  -         -
jailpool/iocage/releases/13.0-RELEASE        canmount  on        default
jailpool/iocage/releases/13.0-RELEASE@auto-2023-02-20_18-47                                                canmount  -         -
jailpool/iocage/releases/13.0-RELEASE/root        canmount  on        default
jailpool/iocage/releases/13.0-RELEASE/root@auto-2023-02-20_18-47                                           canmount  -         -
jailpool/iocage/releases/13.1-RELEASE        canmount  on        default
jailpool/iocage/releases/13.1-RELEASE@auto-2023-02-20_18-47                                                canmount  -         -
jailpool/iocage/releases/13.1-RELEASE/root        canmount  on        default
jailpool/iocage/releases/13.1-RELEASE/root@auto-2023-02-20_18-47                                           canmount  -         -
jailpool/iocage/templates        canmount  on        default
jailpool/iocage/templates@auto-2023-02-20_18-47                                                            canmount  -         -
jailpool/ix-applications        canmount  on        default
jailpool/ix-applications@auto-2023-02-20_18-47                                                             canmount  -         -
jailpool/ix-applications/catalogs        canmount  on        default
jailpool/ix-applications/catalogs@auto-2023-02-20_18-47                                                    canmount  -         -
jailpool/ix-applications/default_volumes        canmount  on        default
jailpool/ix-applications/default_volumes@auto-2023-02-20_18-47                                             canmount  -         -
jailpool/ix-applications/docker        canmount  on        default
jailpool/ix-applications/docker@auto-2023-02-20_18-47                                                      canmount  -         -
jailpool/ix-applications/k3s        canmount  on        default
jailpool/ix-applications/k3s@auto-2023-02-20_18-47                                                         canmount  -         -
jailpool/ix-applications/k3s/kubelet        canmount  on        default
jailpool/ix-applications/k3s/kubelet@auto-2023-02-20_18-47                                                 canmount  -         -
jailpool/ix-applications/releases        canmount  on        default
jailpool/ix-applications/releases@auto-2023-02-20_18-47                                                    canmount  -         -
jailpool/ix-applications/releases/syncthing2                                                               canmount  on        default
jailpool/ix-applications/releases/syncthing2@auto-2023-02-20_18-47                                         canmount  -         -
jailpool/ix-applications/releases/syncthing2/charts                                                        canmount  on        default
jailpool/ix-applications/releases/syncthing2/charts@auto-2023-02-20_18-47                                  canmount  -         -
jailpool/ix-applications/releases/syncthing2/volumes                                                       canmount  on        default
jailpool/ix-applications/releases/syncthing2/volumes@auto-2023-02-20_18-47                                 canmount  -         -
jailpool/ix-applications/releases/syncthing2/volumes/ix_volumes                                            canmount  on        default
jailpool/ix-applications/releases/syncthing2/volumes/ix_volumes@auto-2023-02-20_18-47                      canmount  -         -
jailpool/ix-applications/releases/syncthing2/volumes/ix_volumes/ix-syncthing_config                        canmount  on        default
jailpool/ix-applications/releases/syncthing2/volumes/ix_volumes/ix-syncthing_config@auto-2023-02-20_18-47  canmount  -         -
jailpool/windows10-mmw1q        canmount  -         -
jailpool/windows10-mmw1q@auto-2023-02-20_18-47                                                             canmount  -         -
zpoolbak        canmount  on        default
zpoolbak@auto-2023-02-20_18-47        canmount  -         -
zpoolbak/.system        canmount  on        default
zpoolbak/.system/configs-5a0a2a47cd884dbcbe527966286bfc29                                                  canmount  on        default
zpoolbak/.system/cores        canmount  on        default
zpoolbak/.system/ctdb_shared_vol        canmount  on        default
zpoolbak/.system/glusterd        canmount  on        default
zpoolbak/.system/rrd-5a0a2a47cd884dbcbe527966286bfc29                                                      canmount  on        default
zpoolbak/.system/samba4        canmount  on        default
zpoolbak/.system/services        canmount  on        default
zpoolbak/.system/syslog-5a0a2a47cd884dbcbe527966286bfc29                                                   canmount  on        default
zpoolbak/.system/webui        canmount  on        default
zpoolbak/Backup        canmount  -         -
zpoolbak/Backup@auto-2023-02-20_18-47        canmount  -         -
zpoolbak/PhotoLibrary        canmount  on        default
zpoolbak/PhotoLibrary@auto-2023-02-20_18-47        canmount  -         -
zpoolbak/PhotoLibrary/Multimedia        canmount  on        default
zpoolbak/PhotoLibrary/Multimedia@auto-2023-02-20_18-47                                                     canmount  -         -
zpoolbak/PhotoLibrary/Old Photos        canmount  on        default
zpoolbak/PhotoLibrary/Old Photos@auto-2023-02-20_18-47                                                     canmount  -         -
zpoolbak/PhotoLibrary/Photosync        canmount  on        default
zpoolbak/PhotoLibrary/Photosync@auto-2023-02-20_18-47                                                      canmount  -         -
zpoolbak/PhotoLibrary/Zdrive        canmount  on        default
zpoolbak/PhotoLibrary/Zdrive@auto-2023-02-20_18-47                                                         canmount  -         -
zpoolbak/git        canmount  on        default
zpoolbak/git@auto-2023-02-20_18-47        canmount  -         -
zpoolbak/nextcloud        canmount  on        default
zpoolbak/nextcloud@auto-2023-02-20_18-47        canmount  -         -
zpoolbak/nextcloud/files        canmount  on        default
zpoolbak/nextcloud/files@auto-2023-02-20_18-47                                                             canmount  -         -
zpoolbak/nextcloud/test        canmount  on        default
zpoolbak/nextcloud/test@auto-2023-02-20_18-47                                                              canmount  -         -
root@truenas[~]#
wan2bretired
The remainder,
root@truenas[~]# zfs get mountpoint
boot-pool/.system        mountpoint  legacy        local
boot-pool/.system/configs-3b1c2a4fb0c04f65ad6887d0d3b2bca7                                                 mountpoint  legacy        local
boot-pool/.system/cores        mountpoint  legacy        local
boot-pool/.system/ctdb_shared_vol        mountpoint  legacy        local
boot-pool/.system/glusterd        mountpoint  legacy        local
boot-pool/.system/rrd-3b1c2a4fb0c04f65ad6887d0d3b2bca7                                                     mountpoint  legacy        local
boot-pool/.system/samba4        mountpoint  legacy        local
boot-pool/.system/samba4@wbc-1677013318        mountpoint  -        -
boot-pool/.system/services        mountpoint  legacy        local
boot-pool/.system/syslog-3b1c2a4fb0c04f65ad6887d0d3b2bca7                                                  mountpoint  legacy        local
boot-pool/.system/webui        mountpoint  legacy        local
boot-pool/ROOT/22.12.0        mountpoint  legacy        local
boot-pool/ROOT/22.12.0@2023-02-21-20:48:43        mountpoint  -        -
boot-pool/ROOT/Initial-Install        mountpoint  /        local
boot-pool/grub        mountpoint  legacy        local
jailpool        mountpoint  /mnt/jailpool        default
jailpool@auto-2023-02-20_18-47        mountpoint  -        -
jailpool/.system        mountpoint  /mnt/jailpool/.system        default
jailpool/.system@auto-2023-02-20_18-47        mountpoint  -        -
jailpool/.system/configs-3b1c2a4fb0c04f65ad6887d0d3b2bca7                                                  mountpoint  /mnt/jailpool/.system/configs-3b1c2a4fb0c04f65ad6887d0d3b2bca7                            default
jailpool/.system/configs-3b1c2a4fb0c04f65ad6887d0d3b2bca7@auto-2023-02-20_18-47                            mountpoint  -        -
jailpool/.system/cores        mountpoint  /mnt/jailpool/.system/cores                                                               default
jailpool/.system/cores@auto-2023-02-20_18-47                                                               mountpoint  -        -
jailpool/.system/ctdb_shared_vol        mountpoint  /mnt/jailpool/.system/ctdb_shared_vol                                                     default
jailpool/.system/ctdb_shared_vol@auto-2023-02-20_18-47                                                     mountpoint  -        -
jailpool/.system/glusterd        mountpoint  /mnt/jailpool/.system/glusterd                                                            default
jailpool/.system/glusterd@auto-2023-02-20_18-47                                                            mountpoint  -        -
jailpool/.system/rrd-3b1c2a4fb0c04f65ad6887d0d3b2bca7                                                      mountpoint  /mnt/jailpool/.system/rrd-3b1c2a4fb0c04f65ad6887d0d3b2bca7                                default
jailpool/.system/rrd-3b1c2a4fb0c04f65ad6887d0d3b2bca7@auto-2023-02-20_18-47                                mountpoint  -        -
jailpool/.system/samba4        mountpoint  /mnt/jailpool/.system/samba4                                                              default
jailpool/.system/samba4@auto-2023-02-20_18-47                                                              mountpoint  -        -
jailpool/.system/services        mountpoint  /mnt/jailpool/.system/services                                                            default
jailpool/.system/services@auto-2023-02-20_18-47                                                            mountpoint  -        -
jailpool/.system/syslog-3b1c2a4fb0c04f65ad6887d0d3b2bca7                                                   mountpoint  /mnt/jailpool/.system/syslog-3b1c2a4fb0c04f65ad6887d0d3b2bca7                             default
jailpool/.system/syslog-3b1c2a4fb0c04f65ad6887d0d3b2bca7@auto-2023-02-20_18-47                             mountpoint  -        -
jailpool/.system/webui        mountpoint  /mnt/jailpool/.system/webui                                                               default
jailpool/.system/webui@auto-2023-02-20_18-47                                                               mountpoint  -        -
jailpool/Unbuntu_mani-mla6i5        mountpoint  -        -
jailpool/Unbuntu_mani-mla6i5@auto-2023-02-20_18-47                                                         mountpoint  -        -
jailpool/Unbuntu_mani-mla6i5_unbuntu_sven        mountpoint  -        -
jailpool/Unbuntu_mani-mla6i5_unbuntu_sven@auto-2023-02-20_18-47                                            mountpoint  -        -
jailpool/Unbuntu_mani-mla6i5_unbuntu_sven_vpn                                                              mountpoint  -        -
jailpool/Unbuntu_mani-mla6i5_unbuntu_sven_vpn@auto-2023-02-20_18-47                                        mountpoint  -        -
jailpool/VPNserver-gzptk        mountpoint  -        -
jailpool/VPNserver-gzptk@auto-2023-02-20_18-47                                                             mountpoint  -        -
jailpool/apps        mountpoint  /mnt/jailpool/apps        default
jailpool/apps@auto-2023-02-20_18-47        mountpoint  -        -
jailpool/apps/Clamav-7wfo7m        mountpoint  -        -
jailpool/apps/Clamav-7wfo7m@auto-2023-02-20_18-47                                                          mountpoint  -        -
jailpool/apps/nextcloud        mountpoint  /mnt/jailpool/apps/nextcloud                                                              default
jailpool/apps/nextcloud@auto-2023-02-20_18-47                                                              mountpoint  -        -
jailpool/apps/nextcloud/config        mountpoint  /mnt/jailpool/apps/nextcloud/config                                                       default
jailpool/apps/nextcloud/config@auto-2023-02-20_18-47                                                       mountpoint  -        -
jailpool/apps/nextcloud/db        mountpoint  /mnt/jailpool/apps/nextcloud/db                                                           default
jailpool/apps/nextcloud/db@auto-2023-02-20_18-47                                                           mountpoint  -        -
jailpool/apps/nextcloud/themes        mountpoint  /mnt/jailpool/apps/nextcloud/themes                                                       default
jailpool/apps/nextcloud/themes@auto-2023-02-20_18-47                                                       mountpoint  -        -
jailpool/iocage        mountpoint  /mnt/jailpool/iocage        default
jailpool/iocage@auto-2023-02-20_18-47        mountpoint  -        -
jailpool/iocage/download        mountpoint  /mnt/jailpool/iocage/download                                                             default
jailpool/iocage/download@auto-2023-02-20_18-47                                                             mountpoint  -        -
jailpool/iocage/download/11.3-RELEASE        mountpoint  /mnt/jailpool/iocage/download/11.3-RELEASE                                                default
jailpool/iocage/download/11.3-RELEASE@auto-2023-02-20_18-47                                                mountpoint  -        -
jailpool/iocage/download/12.1-RELEASE        mountpoint  /mnt/jailpool/iocage/download/12.1-RELEASE                                                default
jailpool/iocage/download/12.1-RELEASE@auto-2023-02-20_18-47                                                mountpoint  -        -
jailpool/iocage/download/12.2-RELEASE        mountpoint  /mnt/jailpool/iocage/download/12.2-RELEASE                                                default
jailpool/iocage/download/12.2-RELEASE@auto-2023-02-20_18-47                                                mountpoint  -        -
jailpool/iocage/download/12.3-RELEASE        mountpoint  /mnt/jailpool/iocage/download/12.3-RELEASE                                                default
jailpool/iocage/download/12.3-RELEASE@auto-2023-02-20_18-47                                                mountpoint  -        -
jailpool/iocage/download/13.0-RELEASE        mountpoint  /mnt/jailpool/iocage/download/13.0-RELEASE                                                default
jailpool/iocage/download/13.0-RELEASE@auto-2023-02-20_18-47                                                mountpoint  -        -
jailpool/iocage/download/13.1-RELEASE        mountpoint  /mnt/jailpool/iocage/download/13.1-RELEASE                                                default
jailpool/iocage/download/13.1-RELEASE@auto-2023-02-20_18-47                                                mountpoint  -        -
jailpool/iocage/images        mountpoint  /mnt/jailpool/iocage/images                                                               default
jailpool/iocage/images@auto-2023-02-20_18-47                                                               mountpoint  -        -
jailpool/iocage/jails        mountpoint  /mnt/jailpool/iocage/jails        default
jailpool/iocage/jails@auto-2023-02-20_18-47        mountpoint  -        -
jailpool/iocage/log        mountpoint  /mnt/jailpool/iocage/log        default
jailpool/iocage/log@auto-2023-02-20_18-47        mountpoint  -        -
jailpool/iocage/releases        mountpoint  /mnt/jailpool/iocage/releases                                                             default
jailpool/iocage/releases@auto-2023-02-20_18-47                                                             mountpoint  -        -
jailpool/iocage/releases/11.3-RELEASE        mountpoint  /mnt/jailpool/iocage/releases/11.3-RELEASE                                                default
jailpool/iocage/releases/11.3-RELEASE@auto-2023-02-20_18-47                                                mountpoint  -        -
jailpool/iocage/releases/11.3-RELEASE/root        mountpoint  /mnt/jailpool/iocage/releases/11.3-RELEASE/root                                           default
jailpool/iocage/releases/11.3-RELEASE/root@auto-2023-02-20_18-47                                           mountpoint  -        -
jailpool/iocage/releases/12.1-RELEASE        mountpoint  /mnt/jailpool/iocage/releases/12.1-RELEASE                                                default
jailpool/iocage/releases/12.1-RELEASE@auto-2023-02-20_18-47                                                mountpoint  -        -
jailpool/iocage/releases/12.1-RELEASE/root        mountpoint  /mnt/jailpool/iocage/releases/12.1-RELEASE/root                                           default
jailpool/iocage/releases/12.1-RELEASE/root@auto-2023-02-20_18-47                                           mountpoint  -        -
jailpool/iocage/releases/12.2-RELEASE        mountpoint  /mnt/jailpool/iocage/releases/12.2-RELEASE                                                default
jailpool/iocage/releases/12.2-RELEASE@auto-2023-02-20_18-47                                                mountpoint  -        -
jailpool/iocage/releases/12.2-RELEASE/root        mountpoint  /mnt/jailpool/iocage/releases/12.2-RELEASE/root                                           default
jailpool/iocage/releases/12.2-RELEASE/root@auto-2023-02-20_18-47                                           mountpoint  -        -
jailpool/iocage/releases/12.3-RELEASE        mountpoint  /mnt/jailpool/iocage/releases/12.3-RELEASE                                                default
jailpool/iocage/releases/12.3-RELEASE@auto-2023-02-20_18-47                                                mountpoint  -        -
jailpool/iocage/releases/12.3-RELEASE/root        mountpoint  /mnt/jailpool/iocage/releases/12.3-RELEASE/root                                           default
jailpool/iocage/releases/12.3-RELEASE/root@auto-2023-02-20_18-47                                           mountpoint  -        -
jailpool/iocage/releases/13.0-RELEASE        mountpoint  /mnt/jailpool/iocage/releases/13.0-RELEASE                                                default
jailpool/iocage/releases/13.0-RELEASE@auto-2023-02-20_18-47                                                mountpoint  -        -
jailpool/iocage/releases/13.0-RELEASE/root        mountpoint  /mnt/jailpool/iocage/releases/13.0-RELEASE/root                                           default
jailpool/iocage/releases/13.0-RELEASE/root@auto-2023-02-20_18-47                                           mountpoint  -        -
jailpool/iocage/releases/13.1-RELEASE        mountpoint  /mnt/jailpool/iocage/releases/13.1-RELEASE                                                default
jailpool/iocage/releases/13.1-RELEASE@auto-2023-02-20_18-47                                                mountpoint  -        -
jailpool/iocage/releases/13.1-RELEASE/root        mountpoint  /mnt/jailpool/iocage/releases/13.1-RELEASE/root                                           default
jailpool/iocage/releases/13.1-RELEASE/root@auto-2023-02-20_18-47                                           mountpoint  -        -
jailpool/iocage/templates        mountpoint  /mnt/jailpool/iocage/templates                                                            default
jailpool/iocage/templates@auto-2023-02-20_18-47                                                            mountpoint  -        -
jailpool/ix-applications        mountpoint  /mnt/jailpool/ix-applications                                                             default
jailpool/ix-applications@auto-2023-02-20_18-47                                                             mountpoint  -        -
jailpool/ix-applications/catalogs        mountpoint  /mnt/jailpool/ix-applications/catalogs                                                    default
jailpool/ix-applications/catalogs@auto-2023-02-20_18-47                                                    mountpoint  -        -
jailpool/ix-applications/default_volumes        mountpoint  /mnt/jailpool/ix-applications/default_volumes                                             default
jailpool/ix-applications/default_volumes@auto-2023-02-20_18-47                                             mountpoint  -        -
jailpool/ix-applications/docker        mountpoint  /mnt/jailpool/ix-applications/docker                                                      default
jailpool/ix-applications/docker@auto-2023-02-20_18-47                                                      mountpoint  -        -
jailpool/ix-applications/k3s        mountpoint  /mnt/jailpool/ix-applications/k3s                                                         default
jailpool/ix-applications/k3s@auto-2023-02-20_18-47                                                         mountpoint  -        -
jailpool/ix-applications/k3s/kubelet        mountpoint  legacy        local
jailpool/ix-applications/k3s/kubelet@auto-2023-02-20_18-47                                                 mountpoint  -        -
jailpool/ix-applications/releases        mountpoint  /mnt/jailpool/ix-applications/releases                                                    default
jailpool/ix-applications/releases@auto-2023-02-20_18-47                                                    mountpoint  -        -
jailpool/ix-applications/releases/syncthing2                                                               mountpoint  /mnt/jailpool/ix-applications/releases/syncthing2                                         default
jailpool/ix-applications/releases/syncthing2@auto-2023-02-20_18-47                                         mountpoint  -        -
jailpool/ix-applications/releases/syncthing2/charts                                                        mountpoint  /mnt/jailpool/ix-applications/releases/syncthing2/charts                                  default
jailpool/ix-applications/releases/syncthing2/charts@auto-2023-02-20_18-47                                  mountpoint  -        -
jailpool/ix-applications/releases/syncthing2/volumes                                                       mountpoint  /mnt/jailpool/ix-applications/releases/syncthing2/volumes                                 default
jailpool/ix-applications/releases/syncthing2/volumes@auto-2023-02-20_18-47                                 mountpoint  -        -
jailpool/ix-applications/releases/syncthing2/volumes/ix_volumes                                            mountpoint  /mnt/jailpool/ix-applications/releases/syncthing2/volumes/ix_volumes                      default
jailpool/ix-applications/releases/syncthing2/volumes/ix_volumes@auto-2023-02-20_18-47                      mountpoint  -        -
jailpool/ix-applications/releases/syncthing2/volumes/ix_volumes/ix-syncthing_config                        mountpoint  /mnt/jailpool/ix-applications/releases/syncthing2/volumes/ix_volumes/ix-syncthing_config  default
jailpool/ix-applications/releases/syncthing2/volumes/ix_volumes/ix-syncthing_config@auto-2023-02-20_18-47  mountpoint  -        -
jailpool/windows10-mmw1q        mountpoint  -        -
jailpool/windows10-mmw1q@auto-2023-02-20_18-47                                                             mountpoint  -        -
zpoolbak        mountpoint  /mnt/zpoolbak        default
zpoolbak@auto-2023-02-20_18-47        mountpoint  -        -
zpoolbak/.system        mountpoint  legacy        local
zpoolbak/.system/configs-5a0a2a47cd884dbcbe527966286bfc29                                                  mountpoint  legacy        local
zpoolbak/.system/cores        mountpoint  legacy        local
zpoolbak/.system/ctdb_shared_vol        mountpoint  legacy        local
zpoolbak/.system/glusterd        mountpoint  legacy        local
zpoolbak/.system/rrd-5a0a2a47cd884dbcbe527966286bfc29                                                      mountpoint  legacy        local
zpoolbak/.system/samba4        mountpoint  legacy        local
zpoolbak/.system/services        mountpoint  legacy        local
zpoolbak/.system/syslog-5a0a2a47cd884dbcbe527966286bfc29                                                   mountpoint  legacy        local
zpoolbak/.system/webui        mountpoint  legacy        local
zpoolbak/Backup        mountpoint  -        -
zpoolbak/Backup@auto-2023-02-20_18-47        mountpoint  -        -
zpoolbak/PhotoLibrary        mountpoint  /mnt/zpoolbak/PhotoLibrary        default
zpoolbak/PhotoLibrary@auto-2023-02-20_18-47        mountpoint  -        -
zpoolbak/PhotoLibrary/Multimedia        mountpoint  /mnt/zpoolbak/PhotoLibrary/Multimedia                                                     default
zpoolbak/PhotoLibrary/Multimedia@auto-2023-02-20_18-47                                                     mountpoint  -        -
zpoolbak/PhotoLibrary/Old Photos        mountpoint  /mnt/zpoolbak/PhotoLibrary/Old Photos                                                     default
zpoolbak/PhotoLibrary/Old Photos@auto-2023-02-20_18-47                                                     mountpoint  -        -
zpoolbak/PhotoLibrary/Photosync        mountpoint  /mnt/zpoolbak/PhotoLibrary/Photosync                                                      default
zpoolbak/PhotoLibrary/Photosync@auto-2023-02-20_18-47                                                      mountpoint  -        -
zpoolbak/PhotoLibrary/Zdrive        mountpoint  /mnt/zpoolbak/PhotoLibrary/Zdrive                                                         default
zpoolbak/PhotoLibrary/Zdrive@auto-2023-02-20_18-47                                                         mountpoint  -        -
zpoolbak/git        mountpoint  /mnt/zpoolbak/git        default
zpoolbak/git@auto-2023-02-20_18-47        mountpoint  -        -
zpoolbak/nextcloud        mountpoint  /mnt/zpoolbak/nextcloud        default
zpoolbak/nextcloud@auto-2023-02-20_18-47        mountpoint  -        -
zpoolbak/nextcloud/files        mountpoint  /mnt/zpoolbak/nextcloud/files                                                             default
zpoolbak/nextcloud/files@auto-2023-02-20_18-47                                                             mountpoint  -        -
zpoolbak/nextcloud/test        mountpoint  /mnt/zpoolbak/nextcloud/test                                                              default
zpoolbak/nextcloud/test@auto-2023-02-20_18-47                                                              mountpoint  -        -
root@truenas[~]#
Patrick M. Hausen
Thanks for that. all of this looks good. The last command we could check is the output of mount. But honestly I do not expect any surprises, there.
Last you could do is a clean reinstall and import of your pools. Your jails cannot be migrated, so you will have to do a lot of manual configuration for all your services, anyway.
wan2bretired
This was a clean install, with pool mounts through GUI, but I did load previous configuration.
root@truenas[~]# mount
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,nosuid,relatime,size=3891152k,nr_inodes=972788,mode=755,inode64)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=814624k,mode=755,inode64)
boot-pool/ROOT/22.12.0 on / type zfs (rw,relatime,xattr,noacl,casesensitive)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,inode64)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=102400k,inode64)
cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=13156)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,inode64)
fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
boot-pool/grub on /boot/grub type zfs (rw,relatime,xattr,noacl,casesensitive)
zpoolbak on /mnt/zpoolbak type zfs (rw,noatime,xattr,nfs4acl,casesensitive)
zpoolbak/PhotoLibrary on /mnt/zpoolbak/PhotoLibrary type zfs (rw,noatime,xattr,nfs4acl,caseinsensitive)
zpoolbak/nextcloud on /mnt/zpoolbak/nextcloud type zfs (rw,noatime,xattr,nfs4acl,caseinsensitive)
zpoolbak/git on /mnt/zpoolbak/git type zfs (rw,noatime,xattr,nfs4acl,caseinsensitive)
zpoolbak/PhotoLibrary/Zdrive on /mnt/zpoolbak/PhotoLibrary/Zdrive type zfs (rw,noatime,xattr,nfs4acl,casesensitive)
zpoolbak/PhotoLibrary/Old Photos on /mnt/zpoolbak/PhotoLibrary/Old Photos type zfs (rw,noatime,xattr,nfs4acl,caseinsensitive)
zpoolbak/PhotoLibrary/Multimedia on /mnt/zpoolbak/PhotoLibrary/Multimedia type zfs (rw,noatime,xattr,nfs4acl,caseinsensitive)
zpoolbak/nextcloud/test on /mnt/zpoolbak/nextcloud/test type zfs (rw,noatime,xattr,nfs4acl,caseinsensitive)
zpoolbak/PhotoLibrary/Photosync on /mnt/zpoolbak/PhotoLibrary/Photosync type zfs (rw,noatime,xattr,nfs4acl,caseinsensitive)
zpoolbak/nextcloud/files on /mnt/zpoolbak/nextcloud/files type zfs (rw,noatime,xattr,nfs4acl,caseinsensitive)
jailpool on /mnt/jailpool type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/.system on /mnt/jailpool/.system type zfs (rw,xattr,noacl,casesensitive)
jailpool/apps on /mnt/jailpool/apps type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/iocage on /mnt/jailpool/iocage type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/ix-applications on /mnt/jailpool/ix-applications type zfs (rw,xattr,posixacl,casesensitive)
jailpool/.system/glusterd on /mnt/jailpool/.system/glusterd type zfs (rw,xattr,noacl,casesensitive)
jailpool/.system/services on /mnt/jailpool/.system/services type zfs (rw,xattr,noacl,casesensitive)
jailpool/.system/configs-3b1c2a4fb0c04f65ad6887d0d3b2bca7 on /mnt/jailpool/.system/configs-3b1c2a4fb0c04f65ad6887d0d3b2bca7 type zfs (rw,xattr,noacl,casesensitive)
jailpool/.system/rrd-3b1c2a4fb0c04f65ad6887d0d3b2bca7 on /mnt/jailpool/.system/rrd-3b1c2a4fb0c04f65ad6887d0d3b2bca7 type zfs (rw,xattr,noacl,casesensitive)
jailpool/iocage/download on /mnt/jailpool/iocage/download type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/.system/cores on /mnt/jailpool/.system/cores type zfs (rw,xattr,noacl,casesensitive)
jailpool/iocage/templates on /mnt/jailpool/iocage/templates type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/.system/ctdb_shared_vol on /mnt/jailpool/.system/ctdb_shared_vol type zfs (rw,xattr,noacl,casesensitive)
jailpool/.system/webui on /mnt/jailpool/.system/webui type zfs (rw,xattr,noacl,casesensitive)
jailpool/.system/syslog-3b1c2a4fb0c04f65ad6887d0d3b2bca7 on /mnt/jailpool/.system/syslog-3b1c2a4fb0c04f65ad6887d0d3b2bca7 type zfs (rw,xattr,noacl,casesensitive)
jailpool/.system/samba4 on /mnt/jailpool/.system/samba4 type zfs (rw,xattr,noacl,casesensitive)
jailpool/iocage/download/11.3-RELEASE on /mnt/jailpool/iocage/download/11.3-RELEASE type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/apps/nextcloud on /mnt/jailpool/apps/nextcloud type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/iocage/jails on /mnt/jailpool/iocage/jails type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/iocage/releases on /mnt/jailpool/iocage/releases type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/iocage/download/12.2-RELEASE on /mnt/jailpool/iocage/download/12.2-RELEASE type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/ix-applications/k3s on /mnt/jailpool/ix-applications/k3s type zfs (rw,xattr,posixacl,casesensitive)
jailpool/iocage/download/13.1-RELEASE on /mnt/jailpool/iocage/download/13.1-RELEASE type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/ix-applications/docker on /mnt/jailpool/ix-applications/docker type zfs (rw,xattr,posixacl,casesensitive)
jailpool/ix-applications/releases on /mnt/jailpool/ix-applications/releases type zfs (rw,xattr,posixacl,casesensitive)
jailpool/apps/nextcloud/config on /mnt/jailpool/apps/nextcloud/config type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/iocage/download/12.1-RELEASE on /mnt/jailpool/iocage/download/12.1-RELEASE type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/ix-applications/catalogs on /mnt/jailpool/ix-applications/catalogs type zfs (rw,xattr,posixacl,casesensitive)
jailpool/iocage/download/12.3-RELEASE on /mnt/jailpool/iocage/download/12.3-RELEASE type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/ix-applications/default_volumes on /mnt/jailpool/ix-applications/default_volumes type zfs (rw,xattr,posixacl,casesensitive)
jailpool/apps/nextcloud/db on /mnt/jailpool/apps/nextcloud/db type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/apps/nextcloud/themes on /mnt/jailpool/apps/nextcloud/themes type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/iocage/log on /mnt/jailpool/iocage/log type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/iocage/releases/12.1-RELEASE on /mnt/jailpool/iocage/releases/12.1-RELEASE type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/iocage/releases/11.3-RELEASE on /mnt/jailpool/iocage/releases/11.3-RELEASE type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/iocage/releases/13.0-RELEASE on /mnt/jailpool/iocage/releases/13.0-RELEASE type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/iocage/releases/12.2-RELEASE on /mnt/jailpool/iocage/releases/12.2-RELEASE type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/iocage/releases/12.3-RELEASE on /mnt/jailpool/iocage/releases/12.3-RELEASE type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/iocage/releases/13.1-RELEASE on /mnt/jailpool/iocage/releases/13.1-RELEASE type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/iocage/releases/12.1-RELEASE/root on /mnt/jailpool/iocage/releases/12.1-RELEASE/root type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/iocage/releases/11.3-RELEASE/root on /mnt/jailpool/iocage/releases/11.3-RELEASE/root type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/iocage/releases/13.0-RELEASE/root on /mnt/jailpool/iocage/releases/13.0-RELEASE/root type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/iocage/releases/12.2-RELEASE/root on /mnt/jailpool/iocage/releases/12.2-RELEASE/root type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/iocage/download/13.0-RELEASE on /mnt/jailpool/iocage/download/13.0-RELEASE type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/iocage/releases/12.3-RELEASE/root on /mnt/jailpool/iocage/releases/12.3-RELEASE/root type zfs (rw,xattr,nfs4acl,casesensitive)
jailpool/iocage/releases/13.1-RELEASE/root on /mnt/jailpool/iocage/releases/13.1-RELEASE/root type zfs (rw,xattr,nfs4acl,casesensitive)
boot-pool/.system on /var/db/system type zfs (rw,relatime,xattr,noacl,casesensitive)
boot-pool/.system/cores on /var/db/system/cores type zfs (rw,relatime,xattr,noacl,casesensitive)
boot-pool/.system/samba4 on /var/db/system/samba4 type zfs (rw,relatime,xattr,noacl,casesensitive)
boot-pool/.system/syslog-3b1c2a4fb0c04f65ad6887d0d3b2bca7 on /var/db/system/syslog-3b1c2a4fb0c04f65ad6887d0d3b2bca7 type zfs (rw,relatime,xattr,noacl,casesensitive)
boot-pool/.system/rrd-3b1c2a4fb0c04f65ad6887d0d3b2bca7 on /var/db/system/rrd-3b1c2a4fb0c04f65ad6887d0d3b2bca7 type zfs (rw,relatime,xattr,noacl,casesensitive)
boot-pool/.system/configs-3b1c2a4fb0c04f65ad6887d0d3b2bca7 on /var/db/system/configs-3b1c2a4fb0c04f65ad6887d0d3b2bca7 type zfs (rw,relatime,xattr,noacl,casesensitive)
boot-pool/.system/webui on /var/db/system/webui type zfs (rw,relatime,xattr,noacl,casesensitive)
boot-pool/.system/services on /var/db/system/services type zfs (rw,relatime,xattr,noacl,casesensitive)
boot-pool/.system/glusterd on /var/db/system/glusterd type zfs (rw,relatime,xattr,noacl,casesensitive)
boot-pool/.system/ctdb_shared_vol on /var/db/system/ctdb_shared_vol type zfs (rw,relatime,xattr,noacl,casesensitive)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
boot-pool/.system/cores on /var/lib/systemd/coredump type zfs (rw,relatime,xattr,noacl,casesensitive)
jailpool/ix-applications/k3s/kubelet on /var/lib/kubelet type zfs (rw,relatime,xattr,posixacl,casesensitive)
tmpfs on /var/lib/kubelet/pods/2a68c545-28a2-4341-9c54-43b102873076/volumes/kubernetes.io~projected/kube-api-access-g5lxf type tmpfs (rw,relatime,size=8146228k,inode64)
tmpfs on /var/lib/kubelet/pods/fefa35d9-c4b3-431b-a0c2-321f1d166316/volumes/kubernetes.io~projected/kube-api-access-gpnlq type tmpfs (rw,relatime,size=8146228k,inode64)
tmpfs on /var/lib/kubelet/pods/2f48d4e5-c964-465b-8edf-367d8d642ef4/volumes/kubernetes.io~projected/kube-api-access-7h49r type tmpfs (rw,relatime,size=174080k,inode64)
tmpfs on /var/lib/kubelet/pods/db6327ae-e76a-4794-a978-790cb0032a36/volumes/kubernetes.io~projected/kube-api-access-hgj4g type tmpfs (rw,relatime,size=8146228k,inode64)
overlay on /mnt/jailpool/ix-applications/docker/overlay2/ded4fcf49ddcf5ecefc144e733d56b44463a8c8ab12a5cf033348f9a1056eeb7/merged type overlay (rw,relatime,lowerdir=/mnt/jailpool/ix-applications/docker/overlay2/l/4J2T224NJKQFIHG4GPJT5T5LOY:/mnt/jailpool/ix-applications/docker/overlay2/l/PMIYHD7RI64NCVD763G45SZ7EV,upperdir=/mnt/jailpool/ix-applications/docker/overlay2/ded4fcf49ddcf5ecefc144e733d56b44463a8c8ab12a5cf033348f9a1056eeb7/diff,workdir=/mnt/jailpool/ix-applications/docker/overlay2/ded4fcf49ddcf5ecefc144e733d56b44463a8c8ab12a5cf033348f9a1056eeb7/work)
nsfs on /run/docker/netns/default type nsfs (rw)
shm on /mnt/jailpool/ix-applications/docker/containers/ea540025e8f24c7286973d8a5d2d6108e3b4e7ba21aa11bc6522619121577a4e/mounts/shm type tmpfs (rw,nosuid,nodev,noexec,relatime,size=65536k,inode64)
overlay on /mnt/jailpool/ix-applications/docker/overlay2/95aabcb89f51f69ce3baa2f0bc0602bc86836ac56bd63c8c6f560715942f9d2c/merged type overlay (rw,relatime,lowerdir=/mnt/jailpool/ix-applications/docker/overlay2/l/TUIX3EKGOUFN3CKSXFRVSDC4Y5:/mnt/jailpool/ix-applications/docker/overlay2/l/UADKZXEATNJPJRYFWQTHX5LDM7:/mnt/jailpool/ix-applications/docker/overlay2/l/L2R5RTPX2PLI2XANOXAXOB3VNY,upperdir=/mnt/jailpool/ix-applications/docker/overlay2/95aabcb89f51f69ce3baa2f0bc0602bc86836ac56bd63c8c6f560715942f9d2c/diff,workdir=/mnt/jailpool/ix-applications/docker/overlay2/95aabcb89f51f69ce3baa2f0bc0602bc86836ac56bd63c8c6f560715942f9d2c/work)
jailpool/ix-applications/k3s/kubelet on /var/lib/kubelet/pods/db6327ae-e76a-4794-a978-790cb0032a36/volume-subpaths/chroot-zfs/openebs-zfs-plugin/3 type zfs (rw,relatime,xattr,posixacl,casesensitive)
overlay on /mnt/jailpool/ix-applications/docker/overlay2/5e8b8bcc383068c7e929b72173a48088d705b6791385657c711ce41f6dd74248/merged type overlay (rw,relatime,lowerdir=/mnt/jailpool/ix-applications/docker/overlay2/l/UIEJ4RPREDT4LXLTSJDJURU4LW:/mnt/jailpool/ix-applications/docker/overlay2/l/PTX7CATTLBM7Y4HKX6GSFZRAWS:/mnt/jailpool/ix-applications/docker/overlay2/l/6DI2C24VXZLUV4FT6GBAKSM34P:/mnt/jailpool/ix-applications/docker/overlay2/l/O23LSTI67IEPW7OLSGMCYAZ4JG:/mnt/jailpool/ix-applications/docker/overlay2/l/JYM3CV6EK5BTFIX4CX3KOIAT3Q:/mnt/jailpool/ix-applications/docker/overlay2/l/2R2G76AKIDHQS4SGKN2KDWD7JF,upperdir=/mnt/jailpool/ix-applications/docker/overlay2/5e8b8bcc383068c7e929b72173a48088d705b6791385657c711ce41f6dd74248/diff,workdir=/mnt/jailpool/ix-applications/docker/overlay2/5e8b8bcc383068c7e929b72173a48088d705b6791385657c711ce41f6dd74248/work)
overlay on /mnt/jailpool/ix-applications/docker/overlay2/d335bed1665ee274bbd0c056065e043d0d64a3b0a8a3ad7ac4c8c15eccc7bb9d/merged type overlay (rw,relatime,lowerdir=/mnt/jailpool/ix-applications/docker/overlay2/l/P2F6HXEHSQQDSUV7FXJI7CIMXY:/mnt/jailpool/ix-applications/docker/overlay2/l/PMIYHD7RI64NCVD763G45SZ7EV,upperdir=/mnt/jailpool/ix-applications/docker/overlay2/d335bed1665ee274bbd0c056065e043d0d64a3b0a8a3ad7ac4c8c15eccc7bb9d/diff,workdir=/mnt/jailpool/ix-applications/docker/overlay2/d335bed1665ee274bbd0c056065e043d0d64a3b0a8a3ad7ac4c8c15eccc7bb9d/work)
shm on /mnt/jailpool/ix-applications/docker/containers/00323ca6971fb314788ecee69d682b5a07013967ec432c6afcbc1b54ae178e62/mounts/shm type tmpfs (rw,nosuid,nodev,noexec,relatime,size=65536k,inode64)
nsfs on /run/docker/netns/5b93fce5de9f type nsfs (rw)
overlay on /mnt/jailpool/ix-applications/docker/overlay2/86541f16ae974d5c14511d6456070c44c6b49be6e002ae6710fc7822854fcc2f/merged type overlay (rw,relatime,lowerdir=/mnt/jailpool/ix-applications/docker/overlay2/l/GY2FEOJOBH6GQ2J2XNM2NB3WTW:/mnt/jailpool/ix-applications/docker/overlay2/l/4V4SYHDLKTQ5Z5K6NL3ILWZC74:/mnt/jailpool/ix-applications/docker/overlay2/l/VUDN6CEB6XNQDW3CWINFIXIFPK,upperdir=/mnt/jailpool/ix-applications/docker/overlay2/86541f16ae974d5c14511d6456070c44c6b49be6e002ae6710fc7822854fcc2f/diff,workdir=/mnt/jailpool/ix-applications/docker/overlay2/86541f16ae974d5c14511d6456070c44c6b49be6e002ae6710fc7822854fcc2f/work)
overlay on /mnt/jailpool/ix-applications/docker/overlay2/7c5b35cb3aac5951f2dd188bbe5f212ea95e10e35ff19e2339653fbeff860e83/merged type overlay (rw,relatime,lowerdir=/mnt/jailpool/ix-applications/docker/overlay2/l/2M7BH66E55SMEYH6F4JIND4M7H:/mnt/jailpool/ix-applications/docker/overlay2/l/PMIYHD7RI64NCVD763G45SZ7EV,upperdir=/mnt/jailpool/ix-applications/docker/overlay2/7c5b35cb3aac5951f2dd188bbe5f212ea95e10e35ff19e2339653fbeff860e83/diff,workdir=/mnt/jailpool/ix-applications/docker/overlay2/7c5b35cb3aac5951f2dd188bbe5f212ea95e10e35ff19e2339653fbeff860e83/work)
overlay on /mnt/jailpool/ix-applications/docker/overlay2/6f7aa5545409651dae56af80db529789f85722e7d096a80d0872525cd50bb120/merged type overlay (rw,relatime,lowerdir=/mnt/jailpool/ix-applications/docker/overlay2/l/XREIRKMQ3AMMOSFQUU4OHMCH4M:/mnt/jailpool/ix-applications/docker/overlay2/l/4IDB7EGHIOPIWN67QXKMEXYZS7:/mnt/jailpool/ix-applications/docker/overlay2/l/54DCV4QVRV65U5MCOJQL4A2CAK,upperdir=/mnt/jailpool/ix-applications/docker/overlay2/6f7aa5545409651dae56af80db529789f85722e7d096a80d0872525cd50bb120/diff,workdir=/mnt/jailpool/ix-applications/docker/overlay2/6f7aa5545409651dae56af80db529789f85722e7d096a80d0872525cd50bb120/work)
shm on /mnt/jailpool/ix-applications/docker/containers/03c7e977e0f1604d702b7757662fcea9b12905a186a9b95998c6b385385cf7ba/mounts/shm type tmpfs (rw,nosuid,nodev,noexec,relatime,size=65536k,inode64)
nsfs on /run/docker/netns/d9027f687cf9 type nsfs (rw)
overlay on /mnt/jailpool/ix-applications/docker/overlay2/169d70df6b5b44cb106453b151a0a3da48a0adab6e9dbc22e3a4a642cb895763/merged type overlay (rw,relatime,lowerdir=/mnt/jailpool/ix-applications/docker/overlay2/l/GP3BATOWL3CAN2V57JOVHIMXWV:/mnt/jailpool/ix-applications/docker/overlay2/l/ZHDO5LXW77JIT2UR53PWXJ2M5R:/mnt/jailpool/ix-applications/docker/overlay2/l/54DCV4QVRV65U5MCOJQL4A2CAK,upperdir=/mnt/jailpool/ix-applications/docker/overlay2/169d70df6b5b44cb106453b151a0a3da48a0adab6e9dbc22e3a4a642cb895763/diff,workdir=/mnt/jailpool/ix-applications/docker/overlay2/169d70df6b5b44cb106453b151a0a3da48a0adab6e9dbc22e3a4a642cb895763/work)
overlay on /mnt/jailpool/ix-applications/docker/overlay2/6dbd571684724e19f1831e0e9ad5b47294a18c91be73792de8b8e3786ec6a62a/merged type overlay (rw,relatime,lowerdir=/mnt/jailpool/ix-applications/docker/overlay2/l/GFWGLA3Y6Y2EB5NQCEXTYGX4NI:/mnt/jailpool/ix-applications/docker/overlay2/l/JRPM4QFN4PUQGHHIP2E5DSIQ5K:/mnt/jailpool/ix-applications/docker/overlay2/l/L2R5RTPX2PLI2XANOXAXOB3VNY,upperdir=/mnt/jailpool/ix-applications/docker/overlay2/6dbd571684724e19f1831e0e9ad5b47294a18c91be73792de8b8e3786ec6a62a/diff,workdir=/mnt/jailpool/ix-applications/docker/overlay2/6dbd571684724e19f1831e0e9ad5b47294a18c91be73792de8b8e3786ec6a62a/work)
overlay on /mnt/jailpool/ix-applications/docker/overlay2/b85e2ef6b92b98c668b01603abd8e50fb49d784a94d1ae32a4b3fe50fa8d689a/merged type overlay (rw,relatime,lowerdir=/mnt/jailpool/ix-applications/docker/overlay2/l/75K4Q5Z36DRX3ENAOJJZGUWJTJ:/mnt/jailpool/ix-applications/docker/overlay2/l/PTX7CATTLBM7Y4HKX6GSFZRAWS:/mnt/jailpool/ix-applications/docker/overlay2/l/6DI2C24VXZLUV4FT6GBAKSM34P:/mnt/jailpool/ix-applications/docker/overlay2/l/O23LSTI67IEPW7OLSGMCYAZ4JG:/mnt/jailpool/ix-applications/docker/overlay2/l/JYM3CV6EK5BTFIX4CX3KOIAT3Q:/mnt/jailpool/ix-applications/docker/overlay2/l/2R2G76AKIDHQS4SGKN2KDWD7JF,upperdir=/mnt/jailpool/ix-applications/docker/overlay2/b85e2ef6b92b98c668b01603abd8e50fb49d784a94d1ae32a4b3fe50fa8d689a/diff,workdir=/mnt/jailpool/ix-applications/docker/overlay2/b85e2ef6b92b98c668b01603abd8e50fb49d784a94d1ae32a4b3fe50fa8d689a/work)
overlay on /mnt/jailpool/ix-applications/docker/overlay2/dc25f8e33e0341ba563f6ae3ada9f0e901eb56ed3e16127342ec1c8855fb821a/merged type overlay (rw,relatime,lowerdir=/mnt/jailpool/ix-applications/docker/overlay2/l/JA5BDN5FU33KYHAGZKVDYTOIUG:/mnt/jailpool/ix-applications/docker/overlay2/l/PMIYHD7RI64NCVD763G45SZ7EV,upperdir=/mnt/jailpool/ix-applications/docker/overlay2/dc25f8e33e0341ba563f6ae3ada9f0e901eb56ed3e16127342ec1c8855fb821a/diff,workdir=/mnt/jailpool/ix-applications/docker/overlay2/dc25f8e33e0341ba563f6ae3ada9f0e901eb56ed3e16127342ec1c8855fb821a/work)
shm on /mnt/jailpool/ix-applications/docker/containers/0d533d8e0cc8ec2dee44299490ff40a44188a4cf150c62b85152268a2cffae56/mounts/shm type tmpfs (rw,nosuid,nodev,noexec,relatime,size=65536k,inode64)
nsfs on /run/docker/netns/5a7f187e7e11 type nsfs (rw)
overlay on /mnt/jailpool/ix-applications/docker/overlay2/ffc9bf2805966a07022b2f4160031c995302c2ba0a1818b838026dfae0c3858d/merged type overlay (rw,relatime,lowerdir=/mnt/jailpool/ix-applications/docker/overlay2/l/SAMF6MZTSC2MZNZGHBUJH7VJD3:/mnt/jailpool/ix-applications/docker/overlay2/l/GIML3FJSJ4WJTCNDYHPPHPTEIS:/mnt/jailpool/ix-applications/docker/overlay2/l/PMSVVV7IXKA3ROCSLB2IJY7W36,upperdir=/mnt/jailpool/ix-applications/docker/overlay2/ffc9bf2805966a07022b2f4160031c995302c2ba0a1818b838026dfae0c3858d/diff,workdir=/mnt/jailpool/ix-applications/docker/overlay2/ffc9bf2805966a07022b2f4160031c995302c2ba0a1818b838026dfae0c3858d/work)
jailpool/ix-applications/releases/syncthing on /mnt/jailpool/ix-applications/releases/syncthing type zfs (rw,xattr,posixacl,casesensitive)
jailpool/ix-applications/releases/syncthing/charts on /mnt/jailpool/ix-applications/releases/syncthing/charts type zfs (rw,xattr,posixacl,casesensitive)
jailpool/ix-applications/releases/syncthing/volumes on /mnt/jailpool/ix-applications/releases/syncthing/volumes type zfs (rw,xattr,posixacl,casesensitive)
jailpool/ix-applications/releases/syncthing/volumes/ix_volumes on /mnt/jailpool/ix-applications/releases/syncthing/volumes/ix_volumes type zfs (rw,xattr,posixacl,casesensitive)
jailpool/ix-applications/releases/syncthing/volumes/ix_volumes/ix-syncthing_config on /mnt/jailpool/ix-applications/releases/syncthing/volumes/ix_volumes/ix-syncthing_config type zfs (rw,xattr,posixacl,casesensitive)
tmpfs on /var/lib/kubelet/pods/2b2b03d5-851d-4c8f-9ea6-08118904ee4d/volumes/kubernetes.io~projected/kube-api-access-z2tmn type tmpfs (rw,relatime,size=8146228k,inode64)
overlay on /mnt/jailpool/ix-applications/docker/overlay2/763169d39a303160e824e381f5ab6c3fd48ed126869c232cf97434aaf56f5410/merged type overlay (rw,relatime,lowerdir=/mnt/jailpool/ix-applications/docker/overlay2/l/GMHD67ZRLNRXZ36NIVP6XJA5KA:/mnt/jailpool/ix-applications/docker/overlay2/l/PMIYHD7RI64NCVD763G45SZ7EV,upperdir=/mnt/jailpool/ix-applications/docker/overlay2/763169d39a303160e824e381f5ab6c3fd48ed126869c232cf97434aaf56f5410/diff,workdir=/mnt/jailpool/ix-applications/docker/overlay2/763169d39a303160e824e381f5ab6c3fd48ed126869c232cf97434aaf56f5410/work)
shm on /mnt/jailpool/ix-applications/docker/containers/89f4f7ec184f2870fe81b62418cd287e09fa785ac2dc764cc678a40051a7179d/mounts/shm type tmpfs (rw,nosuid,nodev,noexec,relatime,size=65536k,inode64)
nsfs on /run/docker/netns/9457d60ee3df type nsfs (rw)
overlay on /mnt/jailpool/ix-applications/docker/overlay2/53c9207035a2461bb2c45134b6fd74e32ea44bbdbd2de9120074ba4047c2935f/merged type overlay (rw,relatime,lowerdir=/mnt/jailpool/ix-applications/docker/overlay2/l/BEFMFOUZB675SGCKHX364PK7RN:/mnt/jailpool/ix-applications/docker/overlay2/l/MXGHWW73JMK34QXJFTQSBNVAQH:/mnt/jailpool/ix-applications/docker/overlay2/l/PTSBLOFO7B2NRKYZOJJCIGAWOS:/mnt/jailpool/ix-applications/docker/overlay2/l/Q3QWBYOX5JGIPV5EL7EQPEHOMM:/mnt/jailpool/ix-applications/docker/overlay2/l/JMYEVGCHR52SIYQJ3T6TKK3TZF,upperdir=/mnt/jailpool/ix-applications/docker/overlay2/53c9207035a2461bb2c45134b6fd74e32ea44bbdbd2de9120074ba4047c2935f/diff,workdir=/mnt/jailpool/ix-applications/docker/overlay2/53c9207035a2461bb2c45134b6fd74e32ea44bbdbd2de9120074ba4047c2935f/work)
root@truenas[~]#
Patrick M. Hausen
Then do a factory reset and import the pool but not the configuration ...
Patrick M. Hausen
I would export them in the UI.
wan2bretired
Thanks for your help This worked for the main pool zpoolbak, but not jailpool. The former is the most valuable, the later can be replaced.
My biggest question is this a one off, since I have not read or seen a post with a similar problem? Or might I expect this to happen on my main server of which this server was a copy through replication task, so the data and structure but not hardware are the same?
Thanks again
Patrick M. Hausen
No idea. I have no intention to move from CORE to SCALE. I run a small SCALE system that I setup from scratch to toy with "apps".
